Problem with textarea
I want to include a <textarea> tag in my format file to let my clients submit edits to a large body of text. But the textarea tag doesn't seem to work with CDML. I keep getting an ERR:102, which translates into "Make sure the field you want to modify is on the layout you're using." It is.
Now the -Edit works just fine if I make my input type a standard "text" field.
Has anyone else experienced a similar problem with using <textarea>, and is there a way around it? Here's how I've set up the table using the textarea tag with the CDML. Actually, here's a sample of the whole form:
<form action="FMPro" method="post">
<input type="hidden" name="-DB" value="OnlineDB.fp5">
<input type="hidden" name="-Lay" value="Marketing">
<input type=hidden name="-Error" value="onlinedb/edit_error.htm">
<input type="hidden" name="-Format" value="onlinedb/edit_reply.htm">
<input type=hidden name="-recid" value="[fmp-currentrecid]">
<table width="528" border="1">
<tr bgcolor="#99CC99">
<td><font face="Arial, Helvetica, sans-serif" size="2"><b><font size="3">Human Interest Story</font></b></font></td>
</tr>
<tr>
<td><font color="#000000" size="2" face="Arial, Helvetica, sans-serif">
<textarea name="textarea" rows="10" cols="55" wrap="PHYSICAL" VALUE="[FMP-Field: RLS]">[FMP-Field: RLS]</textarea>
</font></td>
</tr>
<tr>
<td><font face="Arial, Helvetica, Palatino" size="2">
<input type="submit" name="-Edit" value="Submit Changes">
</font></td>
</tr>
</table>
</form>
NEVER MIND!! While reading over my post, I discovered my problem. It's always such a simple thing, isn't it? I had the textarea named "textarea" instead of the FMP field name. So stupid! Putting in the right name for the textarea solved my problem.
Thank you!
  • 4 weeks later...
Always remember to change the "name" of the textarea name="textarea" to name="RLS"
this should work !!
</tr>
<tr>
</font></td>
</tr>
<tr>
</font></td>
</tr>
</table>
</form>
