January 31, 200125 yr If your product database does not contain unique occurances of each product then you should create another level. For example You may have a product database ID / Item 101 = Universal Widget 102 = Left Handed Widget 103 = Right Handed Widget And you could have sub levels for each product. A seperate file would be a child of the main product.. 100.01 = Universal Widget (Small) 100.02 = Universal Widget (Medium) 100.03 = Universal Widget (Large) I hope this helps a little. Inventory systems can get very complex.
January 31, 200125 yr Newbies Hy, My name is Pierre, and a have a little problem, I have to find a way to have the number of product in a database, I cant do a count of the field, cause it will count some product 2 time(cause they are many times in the data base) If a product is 2 time in the database, I must count it one time... please , help me if you can thank Pierre
