IF "2" THEN DISPLAY "6000 CYCLES" ? help
Yet another question from a beginner
I have a field set up with a drop down window for an anticipated life for a battery in years e.g. "2" "8"
but I want a second field to automatically fill its self in when you select 2 or 8 I want the second field to automatically say 6000 or 21000 cycles depending on the time chosen.
Am I way in over my head? Should I be thinking of a more simple way to do this?
make the cycle field a calc:
case(
yearfield = "2"; 6000;
yearfield = "8"; 21000
Slobey has provided a calculation that will do what you request, it can be shorten if you are only having the two choices (i.e. 2 or 8) to:
case(
yearfield = 2; 6000; 21000
BTW, you don't have to put quotes around a number in a calculation.
