Attribs for Products
Greetings,
I have a section on the Database that i am building, it is going to be used for the Attribs.
There is actually 3 tables involved,
* Attribs Controler
* Attribs Value
* Attribs Type
Attribs Type:
The idea of this table is that it allows for you to enter the type for in this case;
* Colour
* Size
Attribs Value:
This table actually holds the values of the Types, so for example;
Colour Black
Colour Red
Attribs Controller:
This is just holds the values entered for each of the products.
[color:blue]Tables
Attrib Controller:
Attrib_ID
Attrib_SortID
Attrib_TypeID
Attrib_TypeValue
Attrib_ValueID
Attrib_ValueValue
Product_ID
Attrib Type:
Attrib_ID
Attrib_SortID
Attrib_Type
Attrib Value:
Attrib_ID
Attrib_SortID
Attrib_Type
Attrib_Type_ID
Attrib_Value
[color:red]Relationships
Attrib Controller:Attrib_TypeID = Attrib Type: Attrib_ID
Attrib Controller:Attrib_TypeID = Attrib Value: Attrib_ID
Attrib Value:Attrib_Type = Attrib Type2: Attrib_Type
[color:orange]The Field Setup
Attribs Controller: Attrib_TypeValue = Drop down list, using values from the field Attrib Type:Attrib_Type
Attribs Controller: Attrib_ValueValue = Drop down list, using values from the field Attrib Value:Attrib_Value; Include only related values starting from: Attrib Type 2.
[color:brown]The Problem
When i select a Type IE: Colour and goto select black from the drop down list, there are no values in the list, they are not showing up.
Anyone have any suggestions,
Thanks (In Advanced)
  • 2 weeks later...
Anyone have any ideas ?
If I follow this correctly (I am not sure what exactly your field names represent), your relationships should be:
Attrib Controller::Attrib_TypeID = Attrib Type::Attrib_Type_ID
Attrib Type::Attrib_Type_ID = Attrib Value::Attrib_Type_ID
and the second value list should show values from Attrib Value::Attrib_Value, include only related values starting from Attrib Type.
This is not the only possible arrangement, but it seems the most sensible to me.
  • 3 weeks later...
Greetings,
Thanks for replying...
I tried that and it didnt work, i actually tried it the first time but just incase there was something i did wrong, i deleted the realationship and tried it again. Still didnt work.
