Printing script problem
I have set up a script to print a layout.
Problem is i need to print one copy to a SHARP printer, then print two copies to a OKI printer.
I set up the print section of the script like this:
Code:
Print Setup[Restore;No Dialog] <= SHARP Printer
Print [Restore;No Dialog] <= 1 copy specified
Pause/Resume Script [Duration(Seconds)B).5]
Print Setup[Restore;No Dialog] <= OKI Printer
Print [Restore;No Dialog] <= 2 copys specified
The problem is is get all copies printing to the SHARP printer.
Each time i go in and set the printers to the appropriate printer, the other one changes to the same printer.
How do i set this up so it stays to the set printers?
Cory,
I've read of this happening, even in FM10.
How about two subscripts: Print_Sharp and Print_OKI
The scripts will have only Print (Restore; No Dialog) steps.
Call them using Perform Script from your existing script.
Sounds odd, I know, and what you have should work, but I've heard that not having two Print (Restores) in the same script helped.
Thank you for the reply.
I did think of breaking it up into 2 scripts, but thought i must have been doing something incorrect with the setup of the printers.
Will do what you recommended. B)-)
