January 6, 201016 yr Happy New Year to you all! I am writing a script that will export field contents (a picture) of the current found set. The way it is currently written, it will export each picture, but you have to choose your output path and hit "Enter" to export each file and move onto the next one. First my question is, how can I make these files export to the user's desktop automatically while retaining their original filename? We are sharing the database on FM Server, so I'd like it to be a universal script. Or if worst comes to worse, I can hard code the output path for each person exporting pictures as long as they don't have to hit enter after each export. Second, is there a way to write some type of calculation field to rename the exported picture automatically to another field's name? I don't see any options to even do this, so I'm not entirely sure it's even possible. Here is what the script looks like so far in case you want to see it: Go to Record/Request/Page [First] Loop Export Field Contents [Database:image] Go to Record/Request/Page [Next; End after last] End Loop Thanks for the help! Appreciated :)
January 6, 201016 yr See if this helps: http://fmforums.com/forum/showtopic.php?tid/179603/post/218603/#218603
January 7, 201016 yr Author BEAUTIFUL! Thank you, comment! Worked like a charm. Show All Records Go to Record/Request/Page [ First ] Loop Set Variable [ $filePath; Value:"filemac:" & Get ( DesktopPath ) & "/ExportedFolder/" & Table::SerialID & ".jpg" ] Export Field Contents [ Table::ImageField; “$filePath” ] Go to Record/Request/Page [ Next; Exit after last ] End Loop
