July 9, 201015 yr Hi, I'm trying to built something that can give not only give me total number of carton, but also to create lines based on a max number per record.. the goal is this. I have to put 10 pieces per box, so if the qty is greater than 10 i need the db to create as many lines as needed. For example for the first line i would just have 1 box of 3. for the second line of 17 i would have 2 boxes (1 with 10 and the 2nd one with 7), for the third line i would have 5 boxes (4 with 10 and the last box with 3) Qty Catalog # 3 427027 17 427028 43 427029 This at the end would create a packing list. the maximum pieces per box are 10 for a single catalog number. Any ideas how this could be done? thanks
July 12, 201015 yr Author Thanks for the calc. Another questions. what can i use to have lines/records created based on the answer from the cealing calc. for example if i put down 50 the qty of cartons would give me 5, but how can i also have it show me cartons 1-5 with 10 each. 1 ----10 2 ----10 3 ----10 4 ----10 5 ----10 i would imagine this would be a portal. Packing_List.zip
July 12, 201015 yr You can use any of these: • A repeating calculation field - see here for something very similar: http://fmforums.com/forum/showpost.php?post/359636/ * A text calculation field, utilizing a recursive custom function; • A portal - with a script to create the related records. This would be my least preferable option, since it requires considerable work (esp. if you change your mind). But it may be necessary if a carton can have attributes other than quantity.
July 12, 201015 yr Author The repeating Calculation field would work perfect, but i have more attributes than just qty. Attributes such as Item Number/Size etc... so it looks like the portal might be the way to go. Do you know of any examples that i can look at that can give me an idea of where to start? I did a search, but nothing looked even close to what i'm trying to do. Thanks
July 12, 201015 yr Are you sure you need a portal? Is this used for anything else other than displaying/printing the packing list?
July 12, 201015 yr Author My only indication why i would need a portal is because i need more information per line eg Max per Carton =10 lines to create packing list for 1-ABCDEF = 30 2-ZXCVB = 13 carton QTY Item Color SIZE 1 10 ABCDEF WHITE M 2 10 ABCDEF WHITE M 3 10 ABCDEF WHITE M 4 10 ZXCVB BLACK S 5 3 ZXCVB BLACK S This would only be for viewing and printing.
July 12, 201015 yr I see that the numbering is consecutive (per order?), even though the items are different. So yes, it would probably be better to have a script create the packing list as records in another table. The script would be roughly: Check if related records exist - if yes, delete them; Load the items and their quantities into variables; Go to the packing list table and loop to create the records.
