Need help writing a script (solved)
I have three tables
Products: id, name, category_id, description
Categories: id, html_template
CategoryFields: id, category_id, key, value
The relationships have all been setup properly.
In Categories::html_template I will have something like this
{name}
  • {size}
  • {length}
  • {width}
now each of the keys (name, size, lenght & width) will be entered via the CategoryFields table.  So every Category will have a different set of keys.
Inside the Products table I set they key values using a portal.
For example
name = "T-Shirt"
size = "M"
length = "50cm"
width = "100cm"
I have a button that will copy the Categories::html_template into Products::description.  I then need it to do a "find and replace" on all the CategoryFields keys (and appending the "{" and "}" ) and then replacing it with the values.
So in the above example, the result would be
T-Shirt
  • M
  • 50cm
  • 100cm
I got this working for fields references inside the products table but am unsure about how to loop over all related CategoryFields.
What script steps should I use to loop over all related records, perform the find and replace and then exit when there are no more keys to replace?
For example
name = "T-Shirt"
size = "M"
length = "50cm"
width = "100cm"
A portal to which table?? Perhaps it would be better if you post an example file.
Well this really sucks but I can't get the size of the file below 1.05M which is required to upload to this site.
I have even tried zipping with and creating a clone with no success.
The Administrators really need to change the upload limit!!
@comment you can download it from here http://droidprofessor.com/tmp/ebayInventory.zip
The script I am editing is called "Product Description from Template"
If you go into the products layout you can run it by pressing the button
Something doesn't make sense here: are ALL products in the 'T-Shirt' category of the SAME size, length and width? If yes, why isn't the Description field in the Category record?
I was just looking at that myself and thinking that I should reference the products table, not the category table.
I will fix it and upload the link, just give me a second
mmmm
come to think of it that will not work either... any ideas?
Did you mean something like this?
MergeByKey.zip
Almost, but what I want if for the Category to control fields. So if I choose a category of T-Shirt, the available fields will display automatically. I could have 100 different products of type T-Shirt and all would share the same keys, however the values would be different for each product.
Well, that's an entirely different issue. One way to do this is to script the creation of new product records, and create the required related records at this time.
@comment I have fixed that problem and now I am back at the initial question, looping through all the related records and replacing the key with the value.
I put the new file back up at
Doesn't my file do just that?
oh, so it does - thanks
