Case (PatternCount) Calculation, need help!!
I don't know if I'm having a major brain fart today, but I can't figure this out.
What I have:
Case( PatternCount( Type; "Receipt") = 0; Expense)
What I need is if the Type = "Receipt" OR "Mileage" to return 0 (False).... but I can't seem to figure it out
Can someone point me in the right direction?
-Thanks
-VX
If there is only one value in the Type field, you could use simply:
Case ( Type ≠ "Receipt" and Type ≠ "Mileage" ; … )
To add an additional criterion into what you are already doing, add some more conditions into your Case() leaving Expense as the default when no conditions are matched.
Case(
PatternCount( Type; "Receipt")>0; 0;
PatternCount( Type; "Mileage")>0; 0;
Expense
Since zero is considered false by FileMaker calcs you can shorten this to
Case(
PatternCount( Type; "Receipt"); 0;
PatternCount( Type; "Mileage"); 0;
Expense
If you find additional words in the future that also need a zero result, you can simply add extra conditions in the same format to the Case().
As Comment states above, if you are sure that Type is restricted to the exact values "Receipt", "Mileage", etc., you can remove the PatternCount() function.
Case(
Type="Receipt"; 0;
Type="Mileage"; 0;
Expense
Wow, I didn't even think to use a reversed statement. I'll have to keep that in mind for future calculations. Thanks, I appreciate it.
Tom, thanks for that as well. The rules of this database change from time to time so adding additional "Types" might occur. Adding another condition is easy enough, I was just having HUGE brain fart. I'm on a low carb diet and I feel kinda hazy.
I guess what you want is:
case ( not PatternCount( Type; "Receipt") or not PatternCount( Type; "Mileage") ; "Expense" )
This shorter form also works, since zero is interpreted as boolean false, and any other (positive) value as true.
Hope this helps.
Hope this helps.
That's what I was attempting to use but I wasn't working. I'm not sure what was going on...
Case( PatternCount("Receipt Mileage"; type ) = 0; Expense)
If you have many values to check, you can switch to something like:
IsEmpty ( FilterValues ( Type ; "Receipt¶Mileage¶Another" ) )
P.S. Beware of PatternCount() in these situations; it can easily return a "wrong" result when one value contains another, e.g. "Receipt" and "Not a Receipt".
Ya, That's why I changed it to your initial suggestion where you dropped the Pattern Count.
Furthermore I decided to make the field contain a drop down list and is validated by that value list. So the field values are limited, but you make a good point.
Grammar
