August 25, 201114 yr Hello, If anyone can point me in the right direction with this it would be greatly appreciated. Basically I have 3 tables: clients, suppliers and transport orders and what I want do is have a drop down list on the transport order layout that shows a list combining client names and supplier names. It is not important that the list shows whether the person is a client or supplier it just needs to show the names. I have been trying to work out the relationship but with no success. Thanks James
August 25, 201114 yr This cannot be done because the clients and suppliers are in different tables. Instead, consider storing clients and suppliers in the same table, with a "type" field to mark them client or supplier.
August 25, 201114 yr Author Hi Vaughan, Thanks for the reply, you've saved me a lot of time in experimenting. Thanks again James
August 25, 201114 yr Author Hello again Vaughan, Just thinking about this, if I have 2 layouts based on the same table, 1 layout for clients and 1 for suppliers can I still differentiate between the 2. eg I will need to have a drop down list for suppliers on a page, on another page I need a drop down for clients and on another for both. Is this still possible? Thanks James
August 25, 201114 yr Author Hi Comment, I have updated my profile, I am using version 11 advanced. Thanks James
August 25, 201114 yr if I have 2 layouts based on the same table, 1 layout for clients and 1 for suppliers can I still differentiate between the 2. A layout can show any/all records from the associated table. To show only records of a certain type, you must perform a find. You can set the layout to do this automatically by using a OnLayoutEnter script trigger. I will need to have a drop down list for suppliers on a page, on another page I need a drop down for clients and on another for both. This has nothing to do with layouts - it's a question of defining three value lists. Two of these need to be conditional (i.e. filtered by a condition). This can be done by defining a relationship and setting the value list to show only related records.
August 28, 201114 yr Author Hello, I have been playing around with the idea of having 2 layouts clients and suppliers, based on one table. On each layout is a field "type" where you choose supplier or client and when you enter each respective layout a script is triggered that performs a find based on the layout to only show records of that type. I have a couple of questions as this is a bit new to me Is it possible to automatically fill in the field "type" on each layout when you start a new record? when you are in on the supplier layout for example, the found set says 3/5 where 3 is the found set of supplier records and 2 is the client record. Is it possible for this to say 3/3 as I think it might be confusing for the user? Will this approach slow the database down? If there are a lot of records, will there be a delay performing the find everytime you open the layout? Any help would be greatly appreciated Thanks James
August 28, 201114 yr On each layout is a field "type" where you choose supplier or client This is not necessary. You either need dedicated layouts (because the fields shown for each type are different) or a single layout with a choice. Is it possible to automatically fill in the field "type" on each layout when you start a new record? Yes, you can set the field to auto-enter a calculated value based on the layout's name. the found set says 3/5 where 3 is the found set of supplier records and 2 is the client record. Is it possible for this to say 3/3 No, but you can hide the status area and show your own message. Will this approach slow the database down? I don't think so - a find on an indexed field is very fast.
August 28, 201114 yr Author Thanks for the reply comment, you have given me lots to think about. James
