September 4, 201114 yr Dear all, I am having an issue about how to count a sub-summary header but yet I forgot how to do it. I attached a small example file. Please take a look at the "Print Layout" layout. In there, I would like to see total customer. Manually, it would be counted as 3 customers, but how to do it in calculation? Thank you for help and suggestion. As usual, if this has been discussed before, please let me know the link and I can read and learn it. Thank you. Test.zip
September 4, 201114 yr See: http://fmforums.com/forum/topic/61158-number-of-employees-from-payroll-report/page__p__289204#entry289204
September 4, 201114 yr Author Hi Comment (Michael), Thank you for your information. Is this working for two tables? I've tried several times but it didn't work as expected. I've tried created 2 new fields on table "ItemPurchased": cInverseCount (calculation) = 1 / GetSummary (sCount ; ItemName ) sCountCustomers (summary) = Total of cInverseCount PS: sCount (summary) = count of ItemName Did I miss something? I've searched this one reciprocal and read this one http://forums.filemaker.com/posts/4f9909b2d0 but the sample file is on the same table. Can it be done on two table? if yes, how? Any help would be appreciated. Thank you.
September 4, 201114 yr Author I think I get it thanks. Well, the problem is I should do on fkCustomer instead of ItemName. That's the issue. But now it's fixed.
