March 8, 200224 yr Greetings Folks On my "Accounts" form I have Date_Paid, Invoice_no, Customer & Total_Paid & Grand_Total fields of which are from my "Invoice" form. When I do a Query of the "Invoice" form for all paid invoices from 1/1/02 to 01/31/02 it finds all the invoices paid in that period & then when I open Accounts form in "View as List" mode, all the details are there, including Total. The problem is that when I go to print them out, I get either just the 1st record or sometimes all the "Total-Paid" fields & the Grand_Total. Any ideas as to why this happens? Thanks in anticipation Sean O'Donoghue
March 10, 200224 yr What records have you set your printer to print? Records being browsed. Current record.
March 10, 200224 yr Author Greetings Folks Am I printing from Portal - Date & Customer are directly inputted & Grand_Total is a summery of Price fields from a portal plus postage costs. And I have set Records being browsed to be printed Regards Sean O'Donoghue
March 10, 200224 yr Ok, so it is not at the printer setting. Sometimes if there is an intrusion into the body from a header, or into the header from a field in the body, and especially with portals if the field encraoches too far into or extends across the portal row there can be printing problems. Try checking this.
March 10, 200224 yr The best idea (especially in this situation) is NOT to print the portal. Goto the related file and generate the report. You will make printing and troublshooting much easier on yourself.
March 14, 200224 yr Author Keith There are no overlaps from or to headers - so it is not that. CaptKurt The problem with this is that only the price is derivative - the monthly total is the sum of prices plus postage - which are in the invoice. Regards Sean O'D London
