Problem updating record using FMEdit
I'm attempting to update the number of times a Knowledge Base Article has been viewed when they click to view the article, however being new to using FX.php I can't seem to get this to work correctly. I would appreciate any insight and feedback on how to set this up correctly. Thank you in advance.
<?php
$kb_articles = $_GET['id'];
// Inialize session
session_start();
error_reporting (E_ALL ^ E_NOTICE);
define("DEBUG", false);
include_once($_SERVER['DOCUMENT_ROOT'] . "/FX/FX.php");
include_once($_SERVER['DOCUMENT_ROOT'] . "/FX/server_helpdesk.php");
$returncount = 1;
$query = new FX($serverIP, $webCompanionPort, $dataSourceType);
$query->SetDBData ("HelpDesk.fp5", "Main", "$returncount");
$query->SetDBUserPass ($webUN, $webPW);
$query->AddDBParam('ID',$kb_articles,'eq');
$result = $query->FMFind();
In the body section of the php page I have:
<?php
foreach ($result['data'] as $key => $value) {
echo '<div id="popupevents">';
echo '<h2>Knowledage Base Article: '.$value['ID'][0].'</h2>';
echo '<table id="kba_table" cellspacing="0" summary="Knowledge Base Article Information" border="1">';
echo '<caption>Knowledge Base Article: '.$value['ID'][0].'</caption> ';
echo '<tr>';
echo '<th scope="col" abbr="Title" class="title" width="25%">Title:</th>';
echo '<td>&nbsp;'.$value['Title'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Category ID">Category:</th>';
echo '<td>&nbsp;'.$value['Category1'][0].', '.$value['Category2'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Summary">Summary:</th>';
echo '<td>&nbsp;'.$value['Summary'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Description">Description:</th>';
echo '<td>&nbsp;'.nl2br($value['Description'][0]).'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Creation Date">Creation Date:</th>';
echo '<td>&nbsp;'.$value['Creation_Date'][0].' by '.$value['Created_By'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Modification Date">Modification Date:</th>';
echo '<td>&nbsp;'.$value['Modification_Date'][0].' by '.$value['Modified_By'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Keywords">Keywords:</th>';
echo '<td>&nbsp;'.$value['Keywords'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Platform">Platform:</th>';
echo '<td>&nbsp;'.$value['Platform'][0].'</td>';
echo '</tr>';
echo '<tr>';
echo '<th scope="col" abbr="Operating System">Operating System:</th>';
echo '<td>&nbsp;'.$value['Operating_System'][0].'</td>';
echo '</tr>';
echo '</table>';
echo '<p class="space"></p>';
echo '<a href="javascript:window.close();">Close This Window</a>';
echo '</div>';
$viewcount = ++$value['Views'][0];
$queryadd = new FX($serverIP, $webCompanionPort);
$queryadd->SetDBData ("HelpDesk.fp5", "Main");
$queryadd->AddDBParam('-recid', $viewcount);
$queryadd->AddDBParam('Views', $viewcount);
$updateResult = $queryadd->FMEdit();
echo $viewcount;
When I echo the $viewcount; it returns the correct value but the 'Views' field in the database isn't being adjusted. I'm sure I have something wrong in the italicized section. Again thanks for your help. -Ken
After doing some more research and experimenting with code I got it to work today. Here is the change that I made:
$recordPointers = explode ('.', $key);
$updateResult = $recordPointers[0];
$queryadd->SetDBUserPass ($webUN, $webPW);
$queryadd->AddDBParam('-recid', $updateResult);
Items in red have been added/modified. If anyone has an easier or cleaner way of doing this please let me know. Thanks.
-Ken
I usually call mine $recID so I know what it's for always, but that's the right idea...
