Need some serious help parsing text
Ok, So below is an example text string i'll be working with
2~11~Test ID~4/19/2012 12:23:51 PM~USER~123.123.123.123
what I am trying to do is to get each section of the text (between each ~) into it's own field.
I can do it to the first section with the following function
Left( Text; Position( Text; "~"; 1; 1 ) - 1 )
But everything fails after that :(
So in the end I am needed to create 6 fields. and those fields "using this example" would show the following.
  1. 2
  2. 11
  3. Test ID
  4. 4/19/2012 12:23:51 PM
  5. USER
  6. 123.123.123.123
Any help would be appreciated!
From your sample it doesnt seem like there would ever be any carriage returns. So your parsing could be as simple as:
Substitute ( "2~11~Test ID~4/19/2012 12:23:51 PM~USER~123.123.123.123"; "~"; ¶ ) or
Substitute ( YourRawField; "~"; ¶ )
Then you can use GetValue ( ) to grab the value that you want.
Perfect-O!
Thanks so much that's exactly what I was looking for.
