Double quotes in applescript - do shell script
I am sorry if this has been posted already. But the search system would not let me use those words.
I am trying to enclose double quotes in a "send apple script", script.
Here is my script.
"¶tell application "& """ & "Finder" & """ & "¶set myTest to do shell script "& """ &"md5 -q "& """ & "/Volumes/Extended/tmp/" & Duplicates::Filename & """ &"¶end tell ¶tell application "& """ &"FileMaker Pro Advanced"& """ &"¶set cell "& """ &"Duplicates::MD5"& """ &" of current record to myTest¶end tell"
"Duplicates::Filename" contains single quotes within the field, so I am unsure how to get that across to the terminal app.
Quoting problems are exactly why I don't suggest ever using that approach.
Use a script to move the data to global fields and then use Perform applescript command instead, something like this.
The purpose of using global fields is that you can use a table reference, you do not need to refer to a layout or current record.
Also, the "herestring" operator "<<<" means you don't have to actually write out the data to a file on disk.
set cellname1 to "zASData"
set cellname2 to "zASResult"
set tableName1 to "Gtest"
get data cell cellname1 of table tableName1
set mydata to result
set cmd to "md5 -q <<< " & quoted form of myData
do shell script cmd
copy result to cell cellname2 of table tableName1
Thanks very much, I would not have looked at it like that!
BruceR,
Okay, I had a chance to implement the new applescript, but I noticed a problem... The here-string is generating the md5 for the actual text within myData, but myData refers to a file location and name that needs to be evaluated by md5.
for example myData = /Volumes/Extended/tmp/_Alice's Restaurant Original Version.mp3 I want to evaluate that file not the text.
Could you please help?
Thanks again.
I figured it out. I have never used the here-string before and looked it up. I just removed it from the calculation and that solved the problem. Thanks again!!!
Thomas
