January 23, 201313 yr Newbies Hello, I need help with a calculation. I am a volunteer working on a database for an organization offering meals on wheels. They have decided to sell prepaid meal cards so the volunteers delivering the meals , need not handle money. Each card is valued at $ 50.00 ( 10 X 5.00 meal) What I need is a calculation which will inform me the service coordinator that the value of a card has expired based on the meals purchased. Then If I have a conditional field based on amount left on card that shows '' need renewal'' then I could have a warning shown that this person needs to renew his card. For example:: 1 Card purchased Jan 1 2013 for Mr X value $50.00 Mr X purchases 2 meals Jan 6 value now $40.00 Mr X purchases 2 meals Jan 15 value now $30.00 Mr X purchases 6 meals Jan 20 Value Now $0.00 Display Dialog '' Mr X needs new card'' Thank you very much in advance,,
January 23, 201313 yr make it simple, I have 3 fields... basically for test.. i always make mistakes.. but with the help of always setting up a debug step situation, watching whats happening... testing watching your vars, there i learned a lot whats happening.. if that makes since I am sure some can put it in 1 line too. field1 have the balance of your card... Xbalance = Xbalance - newPurchases belongs to Joe.. filed2 variable to work with doing some figuring ie, $warning = $10 field3 be a calc field Inside in set up a Case ( Xbalance =< $warning; "Say something "Warning --Need to add money" ) ; "") ///else say nothing field 3 only show if $10 or less hope that helps
January 23, 201313 yr Question: when Mr. X purchases 2 meals - does he charge the purchase to a specific card? Or is it just a matter of maintaining a balance, i.e. purchasing a credit then charging meals against it?
January 23, 201313 yr ya...i added an extra case ) bracket.. like i said.. always check you code, dit da dit
January 23, 201313 yr Author Newbies Comment : He purchases a credit and charges meals against it. RodM: Thank you; I will try this today.
January 23, 201313 yr Author Newbies OK I think I follow but how do I calculate NEW purchases Amount on card - amount purchased based on dates? Date card purchased $ card value Date meal purchased then (quantity x price of meal) I tried an If statement if date of card purchase is > = date of meal purchase then balance = card value - meal price extended Did not work ! Thanks
January 24, 201313 yr Comment : He purchases a credit and charges meals against it. This is more of a relationship issue than a calculation one. If you have a table of Customers and a related table of Transactions, you can simply sum up the transaction amounts at the customer level. You could also replace the Transactions table with separate tables for Cards and Meals = although really, you are talking about managing an account where a card is credit and a meal is debit. You do need to consider the number of transactions over time, since going back to the beginning of time to calculate the present balance may eventually turn out to be too slow.
January 26, 201313 yr If it does not work.. do you use Debug? and Watch Set debug on, execute your code, step through each line of code In step state, use Data watcher tab paste code in there playing with what doesn't work etc. Along with watching your vars, fields etc react
