February 24, 201313 yr Please, could somebody explain how to solve my problem? I have to write down the amount in words in Polish. I found a java code implementing this functionality. (see attached file slownie.java) I want to use method: procKwotaSlownie (double kwota) I compiled the code and put slownie.jar in conteiner field. I used SMLoadJar to register JAR. I would like to use the method (procKwotaSlownie). To this end I used EvaluateGrovy. Unfortunately I get only ERROR.See attached the file with my example database (slownie.fmp12). Thnk you in advance. slownie.zip
February 26, 201313 yr This won't work as you envisage You can do EvaluateGroovy ( "return new slownie()") but you cant do anything with that object This can pretty much be done by a custom function too without recursion If you can explain the rules for the three words you have for million then I can adapt this further.. /** * toWords(number) * 13_02_25 JR * v1.0 * * input: number up to 999 billion * return: amount in (currency) words * depends: <none> * BASED ON http://help.filemaker.com/app/answers/detail/a_id/2860/~/converting-numbers-to-words-or-numbers-to-text * */ Let ( [ //swap these two to test $$CONVERT = number ; //$$CONVERT = 987124765123 ; // translate as necessary then remove live lines below //_hundreds = List ( "One Hundred "; "Two Hundred "; "Three Hundred "; "Four Hundred "; "Five Hundred "; "Six Hundred "; "Seven Hundred "; "Eight Hundred "; "Nine Hundred "); //_teens = List ( "Ten "; "Eleven "; "Twelve "; "Thirteen "; "Fourteen "; "Fifteen "; "Sixteen "; "Seventeen "; "Eighteen "; "Nineteen ") ; //_tens = List ( "Twenty "; "Thirty "; "Forty "; "Fifty "; "Sixty "; "Seventy "; "Eighty "; "Ninety ") ; //_units = List ( "One "; "Two "; "Three "; "Four "; "Five "; "Six "; "Seven "; "Eight "; "Nine ") ; //_currency = List ("dollars" ; "cents") ; //_higher = List ( "Billion, " ; "Billion " ; "Million, " ; "Million " ;"Thousand, " ; "Thousand " ) ; //_joinword = " and " ]; _hundreds = List ( "Sto "; "Dwieście "; "Trzysta "; "Czterysta "; "Pięćset "; "Sześćset "; "Siedemset "; "Osiemset "; "Dziewięćset "); _teens = List ("Dziesięć "; "Jedenaście "; "Dwanaście "; "Trzynaście "; "Czternaście "; "Piętnaście "; "Szesnaście "; "Siedemnaście "; "Osiemnaście "; "Dziewiętnaście ") ; _tens = List ("Dwadzieścia "; "Trzydzieści "; "Czterdzieści "; "Pięćdziesiąt "; "Sześćdziesiąt "; "Siedemdziesiąt "; "Osiemdziesiąt "; "Dziewięćdziesiąt ") ; _units = List ("Jeden "; "Dwa "; "Trzy "; "Cztery "; "Pięć "; "Sześć "; "Siedem "; "Osiem "; "Dziewięć ") ; _currency = List ("zł " ; "game") ; _higher = List ( "Miliard, " ; "Miliard " ; "Milion, " ; "Milion " ;"Tysiąc, " ; "Tysiąc " ) ; _joinword = " and " ]; Case ( $$CONVERT ≥ 1000000000000 ; "ERROR - too big" ; GetValue( _hundreds ;(Int(Mod($$CONVERT;10^12) / 10^11) ) ) & If(Int(Mod($$CONVERT;10^11) / 10^10) = 1; GetValue( _teens ; (Int(Mod($$CONVERT;10^10) / 10^9) + 1 ) ) ; GetValue( _tens ; (Int(Mod($$CONVERT;10^11) / 10^10) -1 ) ) & GetValue( _units ; (Int(Mod($$CONVERT;10^10) / 10^9) ) ) ) & Case(Int(Mod($$CONVERT;10^12)/10^9) and Int(Mod($$CONVERT;10^9) / 10^3); GetValue( _higher ; 1 ); Int(Mod($$CONVERT;10^12)/10^9);GetValue( _higher ; 2 );"") & GetValue( _hundreds ;(Int(Mod($$CONVERT;10^9) / 10^8) ) ) & If(Int(Mod($$CONVERT;10^8) / 10^7) = 1; GetValue( _teens ; (Int(Mod($$CONVERT;10^7) / 10^6) + 1 ) ) ; GetValue( _tens ; (Int(Mod($$CONVERT;10^8) / 10^7) -1 ) ) & GetValue( _units ; (Int(Mod($$CONVERT;10^7) / 10^6) ) ) ) & Case(Int(Mod($$CONVERT;10^9)/10^6) and Int(Mod($$CONVERT;10^6) / 10^3); GetValue( _higher ; 3 ); Int(Mod($$CONVERT;10^9)/10^6); GetValue( _higher ; 4 );"") & GetValue( _hundreds ;(Int(Mod($$CONVERT;10^6) / 10^5) ) ) & If(Int(Mod($$CONVERT;10^5) / 10^4) = 1; GetValue( _teens ; (Int(Mod($$CONVERT;10^4) / 10^3) + 1 ) ) ; GetValue( _tens ; (Int(Mod($$CONVERT;10^5) / 10^4) -1 ) ) & GetValue( _units ; (Int(Mod($$CONVERT;10^4) / 10^3) ) ) ) & Case(Int(Mod($$CONVERT;10^6)/10^3) and Int(Mod($$CONVERT;10^3) / 10^0); GetValue( _higher ; 5 ); Int(Mod($$CONVERT;10^6)/10^3); GetValue( _higher ; 6 );"") & GetValue( _hundreds ;(Int(Mod($$CONVERT;10^3) / 100) ) ) & If(Int(Mod($$CONVERT;100) / 10) = 1; GetValue( _teens ; (Int(Mod($$CONVERT;10) ) + 1 ) ) ; GetValue( _tens ; (Int(Mod($$CONVERT;100) / 10) -1 ) ) & GetValue( _units ; (Int(Mod($$CONVERT;10)) ) ) ) & Case(Int($$CONVERT) > 1; GetValue( _currency ; 1 ); Int($$CONVERT) = 1; GetValue( _currency ; 1 ); "") & If(Mod($$CONVERT; 1) and Int($$CONVERT); _joinword ;"") & If(Mod(Int($$CONVERT*10); 10) = 1; GetValue( _teens ; (Mod(Int($$CONVERT*100); 10) + 1 ) ) ; GetValue( _tens ; (Mod(Int($$CONVERT*10); 10) -1 ) ) & GetValue( _units ; (Mod(Int($$CONVERT*100); 10) ) ) ) & Case(Mod($$CONVERT; 1) > .01 ; GetValue( _currency ; 2 ); Mod($$CONVERT; 1) = .01 ; GetValue( _currency ; 2 );"") ) )
February 28, 201313 yr Author Thank you for your answer. Of course, you are right. Custom Method is a better option, but I wanted to learn how to use my own Java classes. Now I can identify my mistakes. 1. Methods must be public. I had only a public class. 2. The class must be in the package. 3. I used the SMLoadJAR correctly. But I wrongly wanted to use a Java method. In the first step an Import should be done. Example: RegisterGroovy (javamethod(parameter) ; „import package.class; class.method(parameter);”) In Polish the numerals have different forms; example: Jeden Tysiąc (One Thousand) Dwa Tysiące (Two Thousand) Pięć Tysięcy (Five Thousand) Jeden Milion (One Milion) Dwa Miliony (Two Milion) Pięć Milionów (Five Milion)
