Help with Script
Hi
I wonder if someone can help me with a script I'm struggling with. I have got the script below to summarise the total amount of clients we transport between any given dates and to count the number of vehicles used to transport them using two Summary Fields in a table called Journeys.
The first summary field counts the vehicles used i.e minibus, DAR or a car and the second one just totals the amount of clients transported which is extracted from an input field on the journeys layout which is then displayed on another layout called 'clients transported' via a button on the journeys layout.
This works fine but what I'd like to do is summarise the amount of clients transported by vehicle type i.e 6 by DAR, 20 by minibus and 12 by car on the clients transported layout but I just can't work out how to do this so any help would be greatly appreciated.
Show Custom Dialog [ Title: "Clients Transported"; Message:
"Enter the Start and End Date for the month required in the search fields below."; Default Button: “OK”, Commit: “Yes”; Button 2: “Cancel”, Commit: “No”; Input #1: Journey::gStart Date, "Start Date"; Input #2: Journey::gEnd Date, "End Date"; Input #3: Journey::Vehicle, "Specify Vehicle" ]
If [ Get (LastMessageChoice) = 1 ]
Enter Find Mode [ ]
Set Field [ Journey::Start Date; Journey::gStart Date &"..."& Journey::gEnd Date ]
Set Field [ Journey::Number Travelling ]
Set Error Capture [ On ]
Perform Find [ ]
Sort Records [ ] [ No dialog ]
Go to Layout [ “Clients Transported” (Journey) ]
End If
If [ Get (LastMessageChoice) = 2 ]
Go to Layout [ “Journey” (Journey) ]
End If
Thanks in advance.
I am not exactly sure of your structure here but to do what you want, you would create a subsummary report based on your Ride table ( this may be your journey table ), and group on vehicle. You dont need the body portion of the layout. Your summary count field and the vehicle field put on the subsummary part should be enough.
