Problem with IN sub clause
I have a query along the lines of
ExecuteSQL ( "SELECT IDa, Name, Age FROM tableA WHERE  IDa IN ( SELECT IDb FROM tableB WHERE IDc = '1234' )" ; "XX"; "YY" )
I have removed most of the fields to be returned as well as additional WHERE criteria that is working.
I need the XX and YY in the outside query, but I need commas as the record separator for the IN ( SELECT... sub query
Am I missing something obvious....
I would take that IN clause out and run it as its own ExecuteSQL and put the result into a variable. Format it correctly in the fashion IN ('1','2','3'). Then put the variable into your ExecuteSQL you have provided.
Sorry, I clearly didn't provide enough information.
I realise that your suggestion is technically a good solution.  In my circumstances I have a single ExecuteSQL which is dynamically generated.  A variable contains either a basic WHERE structure and or the IN sub query.  To take your suggestion would require fundamental re structuring of what is a parameter driven generic process which I'd rather avoid.
I tried nesting ExecuteSQL, but was unable to get it to work.  I was hoping that there was something clever in SQL itself that would help me (not being an expert myself)
Actual query look more like this
ExecuteSQL ( "SELECT " & $fieldlist & " FROM " & $tablename & " WHERE  " & $whereQuery AND active = 1 " ;  "XX"; "YY" )
Where $whereQuery is either
"IN ( SELECT " & $inField & " FROM " & $inTable &" WHERE " & $qField & " = '" & $qData & "' )"
Or more usually
"$qField & " = '" & $qData & "'"
Thanks for your input.  In responding I have thought of a couple of ideas to try...
