January 8, 201511 yr Newbies Hello, When I run this query: ExecuteSQL ( "select * from Emplacement where NoTerrain = '3' "; ""; ""; "" ) It works. The recording are displayed. However, when I run this query: ExecuteSQL ( "delete from Emplacement where NoTerrain = '3' "; ""; ""; "" ) Error... I get ? as a result, and the query does not work. Could someone explain me the problem ? Thank you for your time.
January 8, 201511 yr you can't. ExecuteSQL() can only do SELECT http://www.filemaker.com/help/13/fmp/en/html/func_ref3.33.6.html#1062707
March 6, 201511 yr Wim is correct - you can only SELECT with ExecuteSQL(). However if you've "found" the records based on the query, then you certainly can DELETE those found records by script.
