Help - Unintentional Window Resizing
I have a script that is attached to a button on a layout.  the script first step of the script opens a new window with sizing parameters and then goes to a layout.  The problem is the script is resizing the window that the button is on, along with opening the new window in the dimensions specified on the New Window step.  I can't figure out why this is happening.  I don't want to change the size of the current layout when opening the new window.  The steps of the script are:
New Window
go to layout
perform find
Sort Records
Enter Preview Mode
Thanks for any suggestions.
I think FileMaker will someday fix this. Until then, your best bet is to add this line before New Window:
Move/Resize Window[ Current Window; Width: Get(WindowWidth) ]
Notice you don't even have to subtract anything from the width or deal with the height. This is sufficient to un-maximize the window in the least intrusive way. If the window is maximized, it will just shrink by a pixel. If it's not, or your user is on a Mac, the window will stay as is.
Well, that is frustrating!  Yes, the original window was maximized, but gets downsized to the size of the new window.
Thanks for the fixes.
Linda
