The difference between a field Reference and a Litteral
I've been working on a series of custom functions for building SQL queries. As I tailor these Custom Functions to meet many different situations and combine them in many different ways as well as making some recursive, I am running into situations where I can send a field reference and other times when I need to send a literal name of a field. What I mean by that is for instance is I am either sending ~SQLfield ( Table::field ) referencing the field or ~SQLfield ( "Table::field" ) using literal text.
If I send as a field reference such as ~SQLfield ( Table::field )
The following works
Let ([
~field = GetValue ( Substitute ( GetFieldName ( ~fieldRef ); "::" ; "¶" ) ; 2 ) ;
~table = GetValue ( Substitute ( GetFieldName ( ~fieldRef ) ; "::" ; "¶" ) ; 1 ) ;
~table = ExecuteSQL (
SELECT DISTINCT BaseTableName FROM FileMaker_Tables
WHERE TableName = ?
;"";""; ~table
Quote ( ~table ) & "." & Quote ( ~field )
If I send as a field reference such as ~SQLfield ( "Table::field" )
The following works
Let ([
~field = GetValue ( Substitute ( ~fieldRef ; "::" ; "¶" ) ; 2 ) ;
~table = GetValue ( Substitute ( ~fieldRef ; "::" ; "¶" ) ; 1 ) ;
WHERE TableName = ?
;"";""; ~table
The difference being in the use of GetFieldName ( ~fieldRef ) when sending a field reference which does not work when sending the field name as a litteral.
So my question is this.
Is there a way within the custom function to determine if the value being passed is a reference or a literal and adjusting accordingly so that passing either ~SQLfield ( Table::field ) or ~SQLfield ( "Table::field" ) could both work?
Edited by Ron Cates
Maybe. But maybe you'd be better off with separate functions.
That's actually what I have done. I was just hoping there was a way so I could consolidate them.
Bam! Racked my brain all day Friday trying to figure it out, came in this morning and there it is!
Thanks Wim :)
