Jump to content
Need easy way to recognize PNG in container
I have an instance where a container field is occupied by an image of unknown type.  It might have been inserted or pasted in ... or imported.
It will be accepted for further processing only if it's a PNG.
How can I easily determine that?  When I look at the actual header bytes of the file (after exporting it), "PNG" is clearly visible.  Yet I wasn't able to get those first 4 bytes with a Left ( text ; 4 ) directly from the container.  Is there a way to do that?
Thanks in advance for any help.
565f5a36ced8b_PNGHeaderBytes.PNG.028bf42
Edited by K1200
Thanks for the response ... but I had looked for some definitive image attribute and couldn't spot one.  Did I miss it?
filename seems to only apply to inserted files and not to pasted images.  But I'll try some additional searches.
What do you get when you put this in Data Viewer?
RightWords ( GetContainerAttribute ( yourTable::yourContainer ; "filename" ) ; 1 )
Note - don't use Get ( FileName ) ... type the literal text just as it shows "filename" ...
It works when I drag an image into the container and also works when I use Insert.
Edited by LaRetta
IIRC, a pasted image would never be PNG. But this might be outdated.
I can copy a png and paste into container and it works in same wayl, at least on El Capitan.  I also imported and got same results.  :-)
It works in Yosemite too
I need to correct myself.  I forgot about the word separator behavior in FM where 'alpha-dot-alpha' is counted as one word.  There are many ways to get the extension from the file name ... here is one:
Let (
name = GetContainerAttribute ( yourTable::yourContainer ; "filename" )
RightValues ( Substitute ( name ; "." ; ¶ ) ; 1 )
or to eliminate the trailing return:
Let (
name = Substitute ( GetContainerAttribute ( yourTable::yourContainer ; "filename" ) ; "." ; ¶ )
GetValue ( name ; ValueCount ( name ) )
Edited by LaRetta
@LaRetta:  Thanks.  That does work.
But in Windows on my PC, I've found that a simple GetAsText also returns the file's name, just like GetcontainerAttribute.  I haven't tested all file types, but it seems to work for PNGs.
Thanks for the other responses, also.
