Need help passing java script to filemaker
I need to pass information to FileMaker, I have passed the information from a java applet to java script, but FileMaker does not seem to want the info...Kind of hurts my feelings.
Here is the source code:
<!-- saved from url=(0022)http://internet.e-mail -->
<HTML>
<HEAD>
<TITLE>HTML file Title</TITLE>
<script language="javascript">
function postInfo()
// get data from the applet
uidStr = document.PWApplet.getUid() ;
pwStr = document.PWApplet.getPw() ;
// validate the data
if (uidStr.length == 0) {
alert("User Name cannot be blank.") ;
return ;
if (pwStr.length == 0) {
alert("Password cannot be blank.") ;
return ;
// copy data from the applet into the hidden form
document.info.uid.value = uidStr ;
document.info.pw.value = pwStr ;
// post the data from the form to FMPro
document.info.submit() ;
// tell the applet to clear its form
document.PWApplet.clearForm() ;
</script>
</HEAD>
<BODY>
<APPLET NAME="PWApplet" CODE="Password4.class" WIDTH=320 HEIGHT=200 MAYSCRIPT>
</APPLET>
<FORM>
<INPUT type="button" value="SUBMIT" onClick="postInfo()">
</FORM>
<FORM name="info" action="FMPro" method="Post" >
<INPUT Type="hidden" Name="uid" value="">
<INPUT Type="hidden" Name="pw" value="">
</FORM>
</BODY>
</HTML>
If someone would be so kind as to tell me what I need to do I would be very thankful!
In Kindness
Stephen K Knight
Stephen Knight
FM WebSchool
www.fmwebschool.com
Stephen,
The "info" form still needs other parameters:
<INPUT Type="hidden" Name="-db" value="mydatabase.fp5">
<INPUT Type="hidden" Name="-lay" value="mylayout">
<INPUT Type="hidden" Name="-format" value="myformat.html">
<INPUT Type="hidden" Name="-find" value="">
</FORM>
Hope this helps.
Garry
At first glance I'd say you need to include the -db, -lay, and -format inputs in your info form.
Thank you guys for all of your help...I did this:
Here are a couple of things I modified:
document.forms[0].username.focus()
Here's how I reference a form (or a field in a form) with JavaScript:
document.forms[0].info.submit()
<FORM name="info" action="FMPro" method="Post">
<input type="hidden" name="-Lay" value="Layout #1">
<input type="hidden" name="-db" value="password.fp5">
<input type="hidden" name="-Format" value="login_succeed.html">
<input type="hidden" name="-Error" value="login_fail.html">
<input type="hidden" name="-op" value="eq">
<Input Type="hidden" Name="find" value="">
</FORM>
I didn't have time to investigate how to add the "-find" command. will it be necessary for this form to complete the login?
Yet it still is missing a step I still get the database error 4
You're one character shy of perfection, from what I can see. Add a hyphen in front of Find, e.g.
<input type="hidden" name="-Find">
And make sure you have "uid" and "pw" on the Layout "Layout #1".
All the best.
Garry
Just a note about the Javascript. You will need to use either:
document.forms[1].submit() ;
or
All the best.
Garry
Got it to work. Of all people I should know I scoured and scoured my code, I had left the "-" off in front of my find. I looked at the code 100 times and didn't see it.
Thank you to everyone that helped! The Applet and Java Script are working perfectly now.
Thank you once again!
Stephen
Funny... recently I was pulling my hair out trying to understand why a simple JavaScript wasn't working on one of my pages. As it happened I had used "If()" instead of "if()". I had nearly rewritten the entire code before I caught that one.
The "If()" has got me before as well; particularly swapping between ASP/VBScript and Javascript frown.gif
Garry
