Problems between Netscape (Mozilla) and CDML tag?
Hi there
I have a question regarding a conflict I came upon.
I made the following code:
<script>
cdml_1 = ("FMPro?-db=Accesses&-format=index.html&all=");
cdml_2 = ("&-New");
cdml = (cdml_1 + content + cdml_2);
window.location = (cdml);
</script>
where content equals a variable calculated in a javascript function.
In internet explorer (I've tried both IE 5 and 6, both in Macintosh and Windows) it works great, and I get the info posted on my database in FMPro.
When I try it in Mozilla (in linux) or any Netscape from 4.0 to 7.01, it "hangs".
Anybody knows a "workaround" for this? Thx in advance.
What if you include the full path? e.g.
cdml_1 = ("http://address/FMPro?-db=Accesses&-format=index.html&all=");
Good Luck.
Garry
Here is another observation. I have been using this syntax:
document.location.replace(cdml) ;
All the best.
Garry
Garry, I've tried both, but unfortunately I had no sucess. The same thing happens.
I've defined the variable content as a global variable (outside the function where I assign the value to it) and still it hangs.
I also tried using either window.location (or document.location.replace) inside the above function, but again it fails.
Any more tips?
Kind regards J
Use:
<script>
var cdml_1 = "[FMP-Link: f]&-format=index.html&all=";
var cdml_2 = "&-New";
var cdml = cdml_1 + content + cdml_2;
window.location = cdml;
</script>
The problem was with your syntax. There is no need for "(" or ")" when your just giving value to a variable.
This should work if you use it as is.
~Addam~
Found the problem. It wasn't the code for the variables cdml_x; I had a problem in an else condition (still don't know why) which IE was permissive enough to pass through it, but netscape wasn't wink.gif. Traded it for a stupid if condition instead (it's hillarious).
Well, that's done. And now for the next battle: Making Safari work with the code. ******* thing only understands some javascript code, but not all. It's giving me problems with recognizing cookies (document.cookie.length > 0) grin.gif
Thanks for all the help m8ies.
J
Don't worry about Safari too much yet, still a fair way to go. Nice and fast though!
All the best.
Garry
