Simple Inlineaction Problems
Have used inlineaction successfully in the past however, despite staring at the following code for 2 days I'm still no closer to figuring out why it only shows and empty drop down. I'm sure it's something simple that I've forgotten and having repeatedly ensured all names were typed correctly would be grateful for any advice.
<select name="product_ID">
[FMP-inlineaction:-db=Graphics_Material.fp5, -lay=web, -max=all, -findall]
[FMP-Record]
<option value ="[FMP-field:Material_Code]">[FMP- Field:Material_Description]
[/FMP-Record]
[/FMP-InLineAction]
</select>
NB: Product_ID is the field to be populated upon completion
Graphics_Material.fp5 is the related DB
Product_ID and Material_Code are the related fields.
Material_Description is the field to be displayed in the drop down.
Is there supposed to be an [fmp-valuelist] ... [/fmp-valuelist] ?
I don't know,
There appears to be a couple of extra spaces here:
<option value ="[FMP-field:Material_Code]">[FMP-Field:Material_Description]
Hope this helps.
Garry
p.s. Are both of these fields on the Layout "web"?
Thanks Guys
Turned out (although I could have sworn I'd checked it) it was down to me forgetting to share the file via web companion.
Iain
Thanks Guys
Turned out (although I could have sworn I'd checked it) it was down to me forgetting to share the file via web companion. Doh!!!
Iain
