Exclude problem !
I want to do a search with exclude. With scriptmaker, I don't able to check the checkbox Exclude or to enter a character in the field to do this. I try "not", "<>" before the value and it don't work.
Help me !
Do your search first before scripting it. Then, in your script use the Perform Find [Restore] step. It will remember the search you just performed.
HTH, Mike
This will work, while I try to avoid Find[restore] as it hides the actual search. Instead I prefer to explicitly set the paramenters of the search. You can perform an "Omit" under script control by using the "Omit Record" script step.
Enter Find Mode []
Set Field[First Name, "John"]
Set Field[Last Name, "Smith"]
New Record/Request
Set Field[City, "New York"]
Omit Record
Perform Find []
-bd
LiveOak,
I agree with you. Your method is the elegant (preferred) solution, while mine was the quick and dirty. wink.gif
Mike
hi Cadderly,
In FileMaker, Exclude = Omit
Much easier to find the answers to questions in the online help and FileMaker Manuel if you use FileMaker's terminology.
