AND/OR problem with CDML booking system
I am making a system using CDML for booking places on events.
I have a page at
http://216.168.37.92/peterb/eventbooker/client_search.htm
which allows the visitor to enter their booking reference and password to view the status of their booking but there are two problems with it:
1. The search needs to only return the record if the visitor enters the booking reference AND the password correctly. I've put
<INPUT TYPE="hidden" NAME="-lop" VALUE=AND>
in the file but if they leave the password field blank (or the reference!) How can I force this behavior?? I've tried a couple of scripts to combine the two fields into one and then search with that with no success yet and setting the "-lop" value to "==" doesn't do it either frown.gif As a temporary measure I've had to ask clients to combine the two themselves into a field which isn't satisfactory
2. When the file is returned I want to include a "field within a field" - So in the dropdown valuelist (itself a field) our staff will use to choose the status of the booking each value includes the name of the event. I have tried using the ,format and ,raw commands with no success, it just returns, for example 'Booking Reserved for [FMP-Field: Event]'
To see the raw search results file go to:
http://216.168.37.92/peterb/eventbooker/client_search_results.htm
The example booking that's on there made has this reference number: 802469128500
and this password: test
Try this:
1. <INPUT TYPE="hidden" NAME="-op" VALUE="=="> just before the "password" field. Note the "-lop" is not needed as the default is "AND" (the format would be name="-lop" value="AND".
Or:
<INPUT TYPE="hidden" NAME="password" VALUE="=="> just before the:
<INPUT TYPE="password" NAME="password" VALUE="">
2. The "dropdown" could look like this (if the ValueList is named "Events"):
<select name="Event">
[FMP-ValueList: Event, List=Events]
<option value="[FMP-ValueListItem]" [FMP-ValueListChecked]>[FMP-ValueListItem]</option>
[/FMP-ValueList]
</select>
All the best.
Garry
Hi, I've been using a Javascript to check that certain fields are filled in.
This looks for any field prefixed "check". I think it will work with dropdowns if the rdeault is "-no selection-"
<HTML>
<HEAD>
<SCRIPT LANGUAGE="JavaScript"><!-- Begin
function checkTheForm(which) {
var pass=true;
if (document.images) {
for (i=0;i<which.length;i++) {
var tempobj=which.elements;
if (tempobj.name.substring(0,5)=="check") {
if (((tempobj.type=="text"||tempobj.type=="password")&&
tempobj.value=='')||(tempobj.type.toString().charAt(0)=="s"&&
tempobj.selectedIndex==0)) {
pass=false;
break;
if (!pass) {
shortFieldName=tempobj.name.substring(8,30).toUpperCase();
alert("You must fill in both name and password");
return false;
else
return true;
// End --></script>
</HEAD>
><FORM ACTION="FMPro" METHOD="post" name=enterform onsubmit="return checkTheForm(this)">
<P>name<BR>
<INPUT TYPE=text NAME="check_username" VALUE="" SIZE=26><BR>
password<BR>
<INPUT TYPE=password NAME="check_password" VALUE="" SIZE=26><BR>
<INPUT TYPE="submit" NAME="-Find" VALUE="submit">
</FORM></FONT></P>
</BODY>
</HTML>
