problems using Javascript with CDML
I want to limit the number of characters a user can enter into a text area on a form. before i put any scripts on my form when the user edits the fields and clicks update, everything works well and the db fields are updated. However once i put the javascript to limit the number of characters in my textarea and then submit the form i get an "unknown error number 102". I know filemaker says this error is about incorrect links or field names but not in this case. Below is the javascript that i have used:
<head>
<script language="javascript" type="text/javascript">
function limitText(limitField, limitCount, limitNum){
if (limitField.value.length > limitNum){
limitField.value = limitField.value.substring(0,limitNum);
}else {
limitCount.value = limitNum - limitField.value.length;
</script>
</head>
<body>
<table>
<tr>
<td class="style1"><div align="right">Contents</div></td>
<td><textarea name="limitedtextarea" onKeyDown="limitText(this.form.limitedtextarea,this.form.countdown,100);" onKeyUp="limitText(this.form.limitedtextarea,this.form.countdown,100);">[FMP-field:drivingsection]</textarea><br>
<font size="1">(Maximum characters: 100)<br>You have <input readonly type="text" name="countdown" size="3" value"100"> characters left.</font></td>
</tr>
Once i put this javascript in the textarea tag i get the error. Has anyone come across this before? Or know of another way i can limit a textarea....the ultimate goal is to limit it to a certain amount of characters based on contents of another field. I have just started with limiting it to 100 characters to test if it would work. Unfortunetly, it doesnt.
Any help much appreciated....
This is one that I use:
<tr><td>Establishment Description:<br>(Limited to 350 characters, approx 60 words)</td>
		<td colspan="2"><textarea name="estab_desc" cols="38" rows="4"><?php echo  $estab_desc ?></textarea></td></tr>
And the Javascript in the <head>
<script>
		function validate()
			with (document.estabfm)
				var subOK = true;
				sEstab_Desc = estab_desc.value;
				if (sEstab_Desc.length > 350)
						subOK = false;
						alert ("The Description is " + estab_desc.value.length + " characters longnPlease shorten!!!");
				if (subOK) { submit(); };
</script>
I use this in the <form> tag:
onsubmit="validate();return false;">
Remember that this:
must be a name of one of the fields in your database.
Garry
