December 30, 200421 yr Hello, I have written a script that loops through a selection of records and sends out an email (using value of global fields as subject and body). I would like to keep a record of what email was sent to whom so I created a related table (related via an auto-generated, unmodifiable number field) to hold this information. Each time an email is sent I would like to automatically create a new record in the related table and fill it with the sequence number of the current record in the loop, the current date, and the subject of the email. I would then display these records via a portal. I thought I could call New Record/Request within the loop but don't see any way to specify the table. Can anyone help me out here? How would I do this? TIA, rlbryant
December 30, 200421 yr Your loop must work like this: Go to portal row first Loop ___Setings of necessary fields of email___ Go to portal row next(exot after last) Endloop
December 30, 200421 yr Author Thanks for the reply. I'm not sure this will work. I need the related records to be created as I am looping through the set of parent records to send the emails. That is, the user finds a selection of records in the parent table and then the script loops through each one to send the email. I don't need to create more than one related record per parent record, so I don't need a loop for the portal records, just for the parent records. Also, I may not necessarily want the first portal row, just whatever portal row is next depending on how many related records have been created when previous emails were sent. I'll give this a try though to see what happens. Maybe the Go to portal row first line is what I need. Currently the script is sending the emails but the related records are not getting created. Thank you for your help, rlbryant Your loop must work like this: Go to portal row first Loop ___Setings of necessary fields of email___ Go to portal row next(exot after last) Endloop
December 31, 200421 yr At this case may be this will help you? Sorry if it isn't what you want. Let Parent table have field Parent_Id. You must to create Parent_Id field in EMails tabel, then create relation "Emails" on this field from Parent to EMails. After in Parent table you can create script Go to record first Loop ____Set Emails::Email_Text,"your text or textfield" ____Go to record next(exit after last) endloop
December 31, 200421 yr Author OK, I've been scouring the forum for clues and I almost have this working. The portal records are getting created but the problem is they are not getting properly related because they are ALL getting the ID (i.e., key) of the first parent record. Here is the script. Can anyone tell me what I am doing wrong? Go to Record/Request/Page [First] Loop Send Mail [No dialog; To: People_Contacts::Email_Address1; Subject: People_Contacts::Global_Email_Subject; Message: People_Contacts::Global_Email_Body] Go to Layout ["Communications1" (Communications)] New Record/Request Set Field [Communications::PC_Sequence_Number; Get(ScriptParameter)] Set Next Serial Value [Communications::Sequence_Number] Set Field [Communications::Communication Type; "Email"] Set Field [Communications::Subject; People_Contacts::Global_Email_Subject] Insert Current Date [select; Communications::Sent] Commit Records/Requests [No dialog] Go to Layout [original layout] Go to Record/Request/Page [Next; Exit after last] End Loop Thanks! rlbryant
January 11, 200521 yr It looks like you're missing part of your Set Next Serial Value step. You're specifying the field, but not the calculation to increment it. Also, what is the ScriptParameter? If it's the parent's key, then of course each new record will have the same foreign key, since the ScriptParameter never changes once the script is called. Additionally, you don't need Insert Current Date. Set Field [Communications::Sent; Get(CurrentDate)] will work and is more reliable.
