February 7, 200521 yr Code: $query->AddDBParam('customer',"cust7","eq"); $query->AddDBParam('status',"closed","neq"); this search should give me all the items for customer - cust7 whose item status is not closed(ie, open). this in filemaker terms would be doing two find request. one for customer = cust7 and another for status = closed ( with the omit tick box checked) so it would give me a result set of 3 which is correct. the fx.php search however gives me 57, obviously incorrect. i even tried with the 'lop' set to 'and' without any joy. if anyone has figured it out, give us a hint. cheers
February 13, 200620 yr Can anyone help with this? I am also trying to figure out how to accomplish a multiple request FM7/FMS7A find via FX.php without nesting loops. Thanks!
February 13, 200620 yr You should be able to do this without the -lop. The following code returns the correct result of 4 from a test on our database. <?php include_once('FX/server_data.php'); include_once('FX/FX.php'); $layout = '########'; $query = new FX ($serverIP, $webCompanionPort); $query -> SetDBData($webDB,$layout); $query -> SetDBPassword($webPW,$webUN); $query ->AddDBParam('FirstField','Yes',"neq"); $query -> AddDBParam('SecondField','Yes',"eq"); $queryResult = $query -> FMFind(); echo $queryResult['foundCount']; ?> If we add in the -lop the result becomes false and returns an incorrect number of records, namely 8. Can you give us more info on the query you are trying to perform.
February 14, 200620 yr I am wanting to find records where: FirstField = Not empty AND SecondField = Not 'Closed' I'm looking for a result very similar to the OP. In FileMaker, we'd perform a find using two requests: 1) First Field = "*" and 2) SecondField = "Closed" with the Omit box checked. This code provides the result I needed: <?php include_once('FX/FX.php'); include_once('FX/server_data.php'); $query = new FX ($serverIP, $webCompanionPort); $query -> SetDBData($webDB,$layout); $query -> SetDBPassword($webPW,$webUN); $query -> AddDBParam('FirstField',' * '); // Note the spaces in ' * ' $query -> AddDBParam('SecondField','Closed','neq'); $query -> AddDBParam('-lop','or'); $queryResult = $query -> FMFind(); ?> Now on to my next problem - using FX.php to query multiple values of the same field like FileMaker allows multiple requests in find mode. Thank you and hope this helps, Shannon
February 14, 200620 yr ok, You want to find an AND here and yet you state the result is correct. On testing it requires you drop the -lop request to determine the correct result. <?php include_once('FX/FX.php'); include_once('FX/server_data.php'); $query = new FX ($serverIP, $webCompanionPort); $query -> SetDBData($webDB,$layout); $query -> SetDBPassword($webPW,$webUN); $query -> AddDBParam('FirstField',' * '); // Note the spaces in ' * ' $query -> AddDBParam('SecondField','Closed','neq'); $queryResult = $query -> FMFind(); ?> Remember the default for FX queries is an AND search. As to using FX to find on the same field for multiple instances, this is when you would use a -lop with 'or'. Hope this helps
February 15, 200620 yr Garry - yes, the SecondField ('status') has many values. Here is my data set: (32 total records) FirstField: 27 empty, 5 not empty SecondField: 4 'Closed', 28 something other than closed. I'm sorry I wasn't clear. In FileMaker, this gives me the desired result: Request 1: set FirstField = '*' Request 2: set SecondField = 'closed' and check the omit box Result: Success: 3 records where FirstField is not empty and SecondField is not 'closed'. In FX.php, I get the same desired result with: $query -> AddDBParam('FirstField',' * '); $query -> AddDBParam('SecondField','Closed','neq'); $query -> AddDBParam('-lop','or'); $queryResult = $query -> FMFind(); Result: Success: 3 records where FirstField is not empty and SecondField is not closed. I believe this is the answer for the OP, Kranky. Now, I originally tried Andy's suggestion: $query -> AddDBParam('FirstField',' * '); $query -> AddDBParam('SecondField','Closed','neq'); $queryResult = $query -> FMFind(); Result: No Joy: 30 records: 25 records where FirstField is empty and SecondField is not closed AND 3 records where FirstField is not empty and SecondField is not closed AND 2 records where FirstField is empty and SecondField is closed (The only two records NOT found were FirstField is not empty and SecondField is Closed) I get the same result in FileMaker when I perform a find on a single request: Request 1: set FirstField = '*' Request 1: set SecondField = 'closed' Request 1: check the omit box Therefore, setting the "-lop" to "or" allowed me to have multiple find requests where one had the omit box checked. Clear as mud? I DO appreciate your feedback Shannon
