How do I keep adding information into same record?
I am new at php. I am creating a survey with 150 question, but using several php pages instead 1.
My problem is to make the information of each page go to the same record instead create a new record.
How do I keep adding information to the same record if I have several php pages.
The code that I have unitil now are:
=======index.php======
<form action="evaluation.php">
<table width="150" border="0" align="center">
  <tr>
    <td width="22"><input name="have_program" type="radio" value="Don't know"></td>
    <td width="118">Don't know </td>
  </tr>
  <tr>
    <td><input name="have_program" type="radio" value="Yes"></td>
    <td>Yes</td>
  </tr>
  <tr>
    <td><input name="have_program" type="radio" value="No"></td>
    <td>No</td>
  </tr>
  <tr>
    <td>&nbsp;</td>
    <td height="25"><input name="name_last" type="text" id="name_last"></td>
  </tr>
  <tr>
    <td>&nbsp;</td>
    <td><input type="submit" name="Submit" value="Continue --&gt;&gt;"></td>
  </tr>
</table>
<div align="center"></div>
<p>&nbsp;</p>
</form>
======evaluation.php======
<?PHP
include_once($HTTP_SERVER_VARS['DOCUMENT_ROOT'] . "/FX/FX.php");
include_once($HTTP_SERVER_VARS['DOCUMENT_ROOT'] . "/FX/server_data.php");
include_once($HTTP_SERVER_VARS['DOCUMENT_ROOT'] . "/FX/FMErrors.php");
$new_member =  new FX($serverIP,$webCompanionPort);
$have_program = $_GET[have_program];
$new_member->SetDBData('survey.fp7','cgi');
$new_member->SetDBPassword('password','admin');
$new_member->AddDBParam('have_program',implode("n", $_GET[have_program]));
<?php
switch ($have_program)
case "Don't know";
include ('do_not_know/new_survey_info.php');
break;
case 'Yes';
include ('thankyou.php');
break;
case 'No';
include ('no/no_continue.php');
break;
default;
echo("only 'yes', 'no', or 'other can be selected.n");
include ('index.php');
=======If I click "No" it will take me to "no_continue.php"============
<?PHP
$new_member->AddDBParam('have_program',$have_program);
$added = $new_member->FMNew();
<body>
<?php
foreach ($added['data'] as $recordKey =>$recordData) {
<?php echo $recordData['survey_id'][0]; ?>
The survey should take no more than 15 minutes to complete. Thank you for your participation
Please <a href="no/research_page.php?area=research_page&survey_id=<?php echo $recordData['survey_id'][0]; ?>">CLICK HERE</a> to continue </p>
<?php } ?>
====research_page.php====
<?PHP
$search_result = new FX($serverIP,$webCompanionPort);
$survey_id = $_GET[survey_id];
$search_result->SetDBData('survey.fp7','cgi');
$search_result->SetDBPassword('password','admin');
$search_result->AddDBParam("survey_id","$survey_id");
$member_list = $search_result-> FMFind();
<body>
 <?php
foreach ($member_list['data'] as $recordKey =>$recordData) {
<form action="no/background_page.php?area=background_page&survey_id=<?php echo $recordData['survey_id'][0]; ?>">
<?php echo $recordData['company_id'][0]; ?>
 <textarea name="research_type" cols="50" value="<?php echo $recordData['research_type'][0]; ?>"></textarea>
<textarea name="research_findings" cols="50" value="<?php echo $recordData['research_findings'][0]; ?>"></textarea>
<input type="hidden" name="recid" value="<?php echo $recordData['recid'][0]; ?>">
<input type="submit" name="Submit" value="Submit">
</form>
<?php } ?>
======background_page.php =====
My problem is here if in case I want to keep entering more information to the same record
how should I do that? Does anyone have any idea?
<?PHP
$research_done = $_GET[research_done];
$research_type = $_GET[research_type];
$research_findings  = $_GET[research_findings];
$additional_info  = $_GET[additional_info];
$future_description_if_yes  = $_GET[future_description_if_yes];
$additional_info2 = $_GET[additional_info2];
$recid = $_GET[recid];
$search_result->AddDBParam("survey_id",$survey_id);
$search_result->AddDBParam("-recid",$recid);
$search_result->AddDBParam("research_type",$research_type);
$search_result->AddDBParam("research_findings",$research_findings);
$member_list = $search_result->FMEdit();
how should I do that? Does anyone have any idea? I tried to have FMfind() but didn't work.
php2005 :confused:
In the "research_page.php" page, can you see the "recid" when you view the page source in the browser?
I notice that you are using a GET in the "background_page.php". Try setting the Form in the "research_page.php" page to "method='POST'". Then change the $_GETs to $_POSTs in the "background_page.php".
Good Luck.
Garry
I agree, use POST to pass values through each page.
<form name="formname" method="post" action="nextpage.php">
If you need to track data across multiple pages for a single record, simply grab the recid early, you can then pass it through each page in a hidden field:
<input type="hidden" name="recid" value="<?=$recid?>" />.
Another track: create a PHP session variable to store the recid on the server. Then grab it as needed. A client-side cookie may work too (probably not here though). Learn more about PHP sessions, security concerns, etc. at http://www.php.net
Hope this helps.
Shannon
Hi Gary and Shannon,
Thank you so much for the help. It is working now.
PHP2005
