Match field problem
Hello,
This is probably a newbie question that I should know the answer to! frown.gif
I have a calculated field that is serving as a match field for two tables. This match field is:
Subject_ID & Initials & Visit_Date
(Side note: In both tables, the Initials field is pulling from a different (third) table.)
The match does not seem to be working - in the portal, I am getting data from the related table, but too much of it, as though the match field is not working properly. It seems to be matching only on the Subject_ID and not including Initials nor Visit_Date.
Could the problem be that Initials is a related field to begin with, or perhaps it is a problem with indexing? Any advice would be much appreciated, I feel like I am going crazy and should know why this is not working!
Regards,
julia
A 'child' table's match field must be indexed in order for a relationship to work. A calculation field involving a related field cannot be indexed, therefore it cannot be used as a match field on the 'child' side.
Is there any chance you can use an auto-entered calculation or a lookup for the field instead? Also, you do not need to make a concatenated field for a relationship anymore; you can make a multi-criteria relationship where
T1::Subject_ID = T2::SubjectID AND
T1::Visit_Date = T2::Visit_Date AND
T1::Initials = T2::Initials
assuming that Initials can be indexed in at least one of the two tables.
