July 3, 200520 yr Have a searchable database on the web using FMP 5.5 and CDML The original search page works fine but I now need to make an amendment. The present page has a -LOP setting of AND because the search can be refined by searching in more than one field as thought necessary. The fields are Town - with user text entry of a full or part name County - selected from a drop down list Postcode - with user text entry of full or part postcode All this works with no problem at all and returns the correct entries. However I now need to also find a record which cannot be found by by using the above search parameters but has a specific entry in another field. I have tried to use the following code just before the -Find. <INPUT TYPE="hidden" NAME ="-LOP'" VALUE="OR"> <INPUT TYPE+"hidden" NAME="Country" VALUE="UK"> My view was that records found by all or any of the first three parameters would now include any records that had UK in the Country field although no matching data in any of the other three fields searched. All that happens is that every record in the database is found and displayed! Have looked at other CDML tags but have not found anything that appears to offer an alternative approach. Is there a way to do what I want?
July 4, 200520 yr Unfortunately, you cannot mix AND/OR in the one request. However, you can use [FMP-If] and other means of achieving the required selection. You may be able to use an [FMP-InlineAction] in the "Not Found" error page to select the alternative. All the best. Garry
July 4, 200520 yr Author Thanks for the tip. After posting my query I continued thinking and believe I have a bit of a kludge that may work. However will also try along the [FMP-If] route.
