System Date problem
I have a System date problem with some dates:
I host an FP3 database by peer sharing on an XP network with other XP users.
Client machines show the correct date calculations;
Host machine will show only a "?" with the same date calc fields;
If I go back to a previously saved version of the databse, the date calc fields display OK;
If I delete all records from that previously-saved version and then re-import current data, the problem re-appears;
The "Use system formats" script step has not helped.
Steve
It's OK - Problem solved.
[The calc fields were in the header of a list view; I was able to make them work when the list was populated with data*]
-I must confess don't know or really care what went wrong any more; we have convinced the Dept to upgrade to FP7.
Now I work in FP7 it's amazing to look back at my past flat-file work and look at the convoluted calc-fields I had to do!)
Steve
