Searching for max values
Sorry if this is an easy questions but I have tried to figure this one out.
I have a real estate database. I am trying to search by a max value. I have set up a drop down list with different price levels ($25,000, $50,000 etc). I have tried the max value script but its not working. I am sure its operator error. Any help would be greatly appreciated.
From the Online Help.
Returns the highest valid value in:
a [color:blue]repeating field (repeatingField).
a field in matching [color:blue]related records specified by (table::field), whether or not these records appear in a portal.
several non-repeating fields in a record ([color:blue]field1;field2;field3...).
corresponding repetitions of repeating fields in a record (repeatingField1;repeatingField2;repeatingField3), if the result is returned in a repeating field with at least the same number of repeats.
several fields in the first matching record specified by ([color:blue]table::field1;table::field2;...). You can include fields from different tables (table 1::field A;table 2::field B...).
So, you would need to do a self relationship and then use the Max Function through the Relationship.
HTH
There are too many unanswered questions here. "I am trying to search by a max value."
Are you searching a table for all records with a value in a Price field UP TO the value you select from your drop-down list; or by records which fall within a range such as between 25,001 and 50,000? If Lee's suggestion doesn't fit the bill, provide more information about your needs. :wink2:
I am searching a table for all records with a value in a Price field UP TO the value you select from a drop-down list. Thanks for the help.
Use a global number (named gPrice) and attach your drop-down to that. Then script would be something like:
If [ not gPrice ]
Show Custom Dialog [ "You need to enter a max price" ]
Halt Script
End If
Set Error Capture [ On ]
Enter Find Mode [ ] (uncheck the Pause)
Set Field [ Price ; ":less:" & gPrice ]
Perform Find [ ]
If [ not Get ( FoundCount ) ]
Show Custom Dialog [ "No records found" ]
... do whatever if no records found
Else
... do whatever with your found set
End If
You can also establish a relationship from this gPrice in your main table to the Price field in another table (or the same table). It's a bit faster and might work better in a drop-down because the results could happen immediately after the drop-down selection (by using a portal) with no need to click a FIND button. Be sure gPrice and Price are same data-type. Join MainTable::gPrice :great: otherTable::Price. If your price is in the same table, create another table occurrence of it and use THAT as your otherTable. You can then use a portal to display the results (automatic) or script a Go To Related Record Records [ Show only related records from "otherTable" ] which switchs to a list or form view of the resulting data-set. Be sure to check box 'Show Only Related' and 'Match Current Record Only.'
You haven't explained how you will be utilizing this search so I can't suggest which method might work best for you.
:smile2:
