Help in write a script
Hi All,
I have a field called “b_number”, how do I write a scrip asking to find the biggest number at b_number field andafter found I will have the add from the b_number +1 added at b_number.
Any help will be appreciated. Thank you in advance.
Why not just use an auto-enter serial number? It would save a lot of work. Can you say a bit more about what you are doing and why? What is that b_number?
I do have a field with an auto serial number. b_number is to used for a receipt number when people paid in full so each time someone paid I have to print a receipt but it have to be in a serial number.
I think you should have a separate table for receipts.
A couple of ways to solve this:
1. Use a relationship and a calc:
Max(related:;)_number)+1
2. Or, use a script something like:
Show All
Go to record(last)
Set variable($theBiggest;b_number)
New record
Set field(b_number;$theBiggest+1)
Why does this forum sometimes break text apart?
