February 24, 200224 yr Newbies I'm an asp/asp.net programmer and I'm new to filemaker. I recently took on a small project to help a non-profit company here in town port their filemaker databases to the web. So far it's been a nightmare, especially cdml and filemaker's limited web capabilities. Now, my problem... I have a 'column' in the filemaker db I'm working with called "In Calendar". I need to exclude everything in that 'column' that is equal-to "No" so events that are not public do not show up on the web as they use this db internally to track their theater events. So, I figured great!...I'll say "pick everything that does not equal 'No' in 'In Calendar'", however, this doesn't work. It's treating not-equals exactly the same as equals. Here's some code: ** html snippet on "search" page (hidden fields) *** <FORM ACTION=FMPro METHOD=post> <INPUT TYPE=hidden NAME=-DB VALUE='Events'> <INPUT TYPE=hidden NAME=-Lay VALUE='Event Entry'> <INPUT TYPE=hidden NAME="-format" VALUE="search_results.htm"> <INPUT TYPE=hidden NAME="-error" VALUE="search_error.htm"> <INPUT TYPE=hidden NAME=-SortField VALUE='Date of Event'> <INPUT TYPE=hidden NAME="-SortORder" VALUE=Ascending> <INPUT TYPE=hidden NAME="-max" VALUE=all> <INPUT TYPE=hidden NAME="-lop" VALUE=AND> <INPUT TYPE=hidden NAME="-op" VALUE=ne> <INPUT TYPE=hidden NAME='In Calendar' VALUE='No'> *********************************************** Rather than getting the fields that do-not-equal 'No' I get the ones that equal No......frustrating. I'm using claris home page to generate most of this as I'm not familiar w/ cdml and really have no vested interest in taking it up, just want to get through this *simple* project and be on my way. Thanks very much ahead of time everyone!!
February 24, 200224 yr Why do you use the < INPUT TYPE=hidden NAME="-lop" VALUE=AND>? code: Specifies the comparison operator to apply to the field name/value pair that follows it in a -Find action. Value is The operator to use. There are short and long versions of each operator. The default operator is "begins with". The list of valid operators is: Short Long FileMaker Pro Equivalent Operator eq equals =word cn contains "word" bw begins with word* ew ends with *word gt greater than > word gte greater than or equals >= word lt less than < word lte less than or equals <= word neq not equals omit, word As you see it is "neq" and not "ne" RE: and filemaker's limited web capabilities. ::?
February 25, 200224 yr USE THIS RESOURCE OFTEN. http://www.filemaker.com/support/index.html Search and read: Article Number: 104829, and Article Number: 105687 Understanding this will help. Also understanding the way FMPro really handles -lops can be found in a good book about the way the db works. Believe me when I tell you that it is easy to confuse what FMPro can do as a directly accessed db and what it can do as an indirectly (vis a vis the www) accessed db. You don't say so in your code, but I would assume that you are doing a -find action.
February 26, 200224 yr quote: Originally posted by V: I love you! I have no problem with that Being Rock Idol in seventies-eighties I am use to it Does it work now?
