Help - add record into a field using fx.php
I have a relational database and in one of the layout I have a portal which shows a list of record, my problem is if I want to add more information to a field which is a portal to that ID number using the fx.php how would I do in order to do not delete the previous record. I am not sure what am I doing wrong. Any help will be appreciated.
Here is what I have:
$edit_member = new FX($serverIP,$webCompanionPort);
$company_id = $_GET[company_id];
$name= $_GET[name];
$recid = $_GET[recid];
$edit_member->SetDBData(members.fp7',’web’);
$edit_member->AddDBParam('-recid',$recid);
$edit_member->AddDBParam('company_id',$company_id);
$edit_member->AddDBParam('name',$name);
$edited = $edit_member->FMEdit();
<?php
foreach ($edited['data'] as $recordKey =>$recordData) {
<?php echo $recordData['company_id'][0]; ?>
<?php echo $recordData[‘name’][0]; ?>
<?php } ?>
Thank you
