checkbox values using setField and $_ POST
hello..
i have a form with several checkboxes available for each hotel room night:
Nite_1_Check
Nite_2_Check
if i submit the form WITH a box checked, no problem. If i don't select the box and submit, it errors out "Notice: Undefined index: Nite_1_Check... Here's what i started with:
$edit->setField('Nite_1_Check', $_POST['Nite_1_Check']);
when that didn't work (if unchecked), i tried several variations of:
if ($_POST['Nite_1_Check'] != NULL) {
  } else {
  $edit->setField('Nite_1_Check', NULL);
but that doesn't work. Since all of my other (non- checkbox) fields work fine, i have a feeling this has something to do with PHP not being able to send/POST a NULL value(?). Am i approaching this right?
thanks..
got it.. i had to use an "isset"
if (isset($_POST['Nite_1_Check'])) {
		} else {
works great.. hooray for trial/error :
