question using the function Max
Hi all
I have a record id field that is formatted as text. The information that is in this field is a combination of numbers and text.
Example :P 3700 FCAW -s 773211
The last number is a date converted to numbers
I am trying to find the maximum record ID using the Max function. But only that is displayed is the numbers
Example: 3700773211
I will assume that the Max function in this case cannot displayed text and number together and is there a other function to achive what I would like to do.
Lionel
Hi
If we have these IDs:
1500 ABCD -z 773211
1000 EFGH -a 773211
0001 ILMN -u 773211
which one must be the Max for you and why ?
Daniele
There will never have ID's as you noted below.
1500 ABCD -z 773211
1000 EFGH -a 773211
0001 ILMN -u 773211
The record ID is created for a Welder program that we use at work. A new Record is created every couple months for each welding process that a welder is qualified to use.
so the record ID maybe as follows
3700 FCAW -s 771132
3700 FCAW -s 771248
3700 FCAW -s 771367
using the max function which is formatted as a text field will display
3700771367
Lionel
I think the easiest solution would be to adhere to the "one fact per field" rule and split the data into two (or more?) fields.
Have you considered using the Max function with the RightWord function?
thanks for the information. Will do that but is this what the Max function is suppose to display when the field contains numbers and text?
Lionel
Yes - see:
http://fmforums.com/forum/showtopic.php?tid/193363/
thanks
