January 11, 200917 yr I am creating a database for a Landscape contractor business. ( my brother's ) I have Job table with a "date_start_job" field, a "date_end_job" field, and also a "duration_job" calculation field which is ( "date_start_job" - "date_end_job" ) . There is also a number field called "estimate_duration_job". What I want to do is have a message appear that shows all jobs which are overdue. Overdue jobs are jobs where the "date_end job" is bigger than the ("date_start_job" + "estimate_duration_job") but also where the current date is bigger than ("date_start_job" + "estimate_duration_job") I created the following calc. but unfortunately it doesn't do the job. My problem is that I can get it to calculate if the "date_end_job" is populated, but if this field is empty it will not calculate. See calculation : Case ( duration_job > duration_estimate_job ; "This Job has overrun by " & duration_job - duration_estimate_job & " " & "Days" ; ) I tried this other calculation and got wrong results as well Case ( IsEmpty ( date_end_job ) ; and (date_start_job + duration_estimate_job ;> ( Get ( CurrentDate ); "This Job has overrun by " & duration_job - duration_estimate_job & " " & "Days" ) ) ) Any help is greatly welcomed. Edited January 11, 200917 yr by Guest
January 11, 200917 yr Try: Let ( [ end = Case ( date_end_job ; date_end_job ; Get (CurrentDate) ) ; dur = end - date_start_job ] ; Case ( dur > duration_estimate_job ; "This job has overrun by " & dur - duration_estimate_job & " days" ) ) --- Make sure the calculation is unstored, so that it updates with current date. Edited January 11, 200917 yr by Guest
January 11, 200917 yr Author Thank you very much for your reply. I am realy gratefull for your help. It worked like a charm.
January 11, 200917 yr Let ( [ jobDone = NOT IsEmpty ( date_end_job ) ; daysOver = Case ( jobDone; date_end_job - date_start_job - estimate_duration_job ; Get ( CurrentDate ) - date_start_job - estimate_duration_job ) ] ; Case ( daysOver > 0 ; "This Job " & Case ( jobDone ; "has overrun " ; "is overrunning " ) & "by " & daysOver & " Day" & Case ( daysOver > 1 ; "s" ) ) ) Edited January 11, 200917 yr by Guest
January 11, 200917 yr That's what happens when I take break before responding! Well, I'm leaving mine, Michael, because yours doesn't display nicely if there is only 1 day. ROFLMAO!! UPDATE: Oh, and I ditched the calculation of actual duration because I suspected it wasn't necessary by itself and I dislike calcs whose only purpose is to be used in another calc. I might be wrong here however ... 2ND UPDATE: And Michael's calc is prettier in general but I would certainly correct the text portion. :wink2: Edited January 11, 200917 yr by Guest Added update and then 2nd update
January 11, 200917 yr Author Thank you for trying to help, but the calc. : Let ( [ jobDone = NOT IsEmpty ( date_end_job ) ; daysOver = Case ( jobDone; date_end_job - date_start_job ; Get ( CurrentDate ) - date_start_job - estimate_duration_job ) ] ; Case ( daysOver > 0 ; "This Job " & Case ( jobDone ; "has overrun " ; "is overrunning " ) & "by " & daysOver & " Day" & Case ( daysOver > 1 ; "s" ) ) ) didn't realy work, because it seems to ignore the end date when this is entered.
January 11, 200917 yr I had corrected my calc. YOu might check it again. Comment's calc is actually better but I wouldn't want to modify his to include my text result (which I think IS better). :blush2: Edited January 11, 200917 yr by Guest
January 11, 200917 yr Author I have attached a copy of the DB for you to check is you could. The calc doesn't seem to update. Thank you for your help.
January 11, 200917 yr No attachment? I'll attach mine. I suspect that you missing this part: Make sure the calculation is unstored, so that it updates with current date. I suppose I should have repeated it but when I saw it on his calc, I assumed you understood that, since Get ( CurrentDate ) was in the calculation, it would need to be unstored. If I'm still missing something, please let us know. :wink2: Jobs.zip
