February 27, 200917 yr Does anyone know a good solution for: Error: 7 - Running out of memory I'm publishing a db to the web and I am getting this error message. I've reduced the amount of fields to 3 simple text fields and I'm still getting this message. Thanks, Scott
April 2, 200917 yr I'll second this request for help-- I've created a dead-simple tiny db to test with, and still get this error. Also, monitoring memory usage, I see that memory is nowhere near capacity, so the error message is spurious. Error logs don't specify any particular area in the php file, alas (sometime poorly formed php will give a line number where an error occurred). I can hand code a simple php page (w/o accessing FMP), which will display properly, so it's not a problem with the php install. Did a clean install of OS X Server before installing FMS 10, so system settings are pretty standard. Single machine setup, FMP & PHP & Apache all on the same box, no external links. Suggestions?
April 14, 200916 yr FWIW: Setting in OS X Server seems to have been at fault: In Server Admin, select Web service, click on the Sites tab, and under General options for the web site, the third line down (at least in server version 10.5.6) is IP Address:. Setting this field to the IP address of the box bollixed things up; setting it to "any" from the drop-down list allows FM PHP to run properly. No clue why....:confused:
March 22, 201313 yr Hi. I am also getting the same error but did not find ip address place in filemaker server 12? Any clue?
