Problem with AND/OR. Very urgent!
How to use AND OR both in the same page.
I have a problem when working with "AND" and "OR" using CDML.
My problem is "I have a search page for searching the database.In that search page i have 2 sets of input fields.For one set of fields the logical operator AND/OR should be assigned according to the user selection.And for the second set of records the logical operator should be always "AND".
I think you guys understand the exact problem.I don't know how to implement this in my search page.Is that possible to assign "OR" for oneset of fields and "AND" for other set of records in the same page?
If so please let me know.
I'm eagerly waiting for your replies.
Advanced thanx for u all.
Sree
This is just a guess. What happens if you place a "AND" prior to the relevent fields in the form. Then place an "OR" prior to its relevent fields.
I.E. Does "LOP" placement at various locations in the form have the desired effect!
All the best.
Garry
