Newb needs help with relationship schema
I am by no ways or means a database programmer but I understand most concepts enough to create what I need to. But I admit I'm always stumped on what is probably a straight forward concept for most of you.
I have the typical company (just one) with typical customers (many) creating quotes/invoices (many) with plenty of items for said invoices. I have no problem with creating a master invoice table with relationships to customer table and a relationship to the items table (and some of the items have relationships to subitems)...but I really don't know the correct way to tie a single company record to all of this.
Right now since the company record is just name/address and some misc variables I use global storage, create a unique ID field and use auto-enter of that unique number into the foreign key field of the other tables. somehow I don't think this is correct so what would be the proper way to do it or is there a good example somewhere I could rip apart and get a really good feel for the correct way to do things?
any help and advice is much appreciated!
What do you expect to happen later on?
Probably very little as far as company records go. Possibly changes to phone/email or changes in tax rate.
You can have a single record "preferences" type of table to store this data. Typically when reselling a product you would have this to store the company data, logo, address, phone etc. This table can be related to the other tables using a Cartesian (X) join or you can have them loaded into globals via a startup script.
As for tax rate, it would be based on customer if dealing with multiple tax rate scenarios. If the is a POS system though then you could store this in the preferences table as well.
Assuming you want each invoice to store the phone/email as it was at the time the invoice was issued (and you definitely want each invoice to store the applicable tax rate), define those fields to auto-enter the data from the global fields.
Another option is to have a one-record Preferences table, and look up the data from there. This makes it easier to change the preferences while the file is being served - but it also requires either a relationship between Preferences and Invoices (and any other table using them), or a startup script to load the preferences into global fields/variables.
