Using with custom web publishing
I have a script that sends bulk emails using ScriptMaster. It runs fine as a scheduled script from the server, but I can't get it working when run through custom web publishing (php).
Screen shot of the script is attached.
Basically I want to run it from a button instead of as a scheduled script every 5 minutes clogging up resources & log files, so I created a php script that runs the script, and attached a button to the php page using "Go to URL".
I know the script is running because it is writing the error (see script).
The following debug calculation:
"ERROR " & SMLastError & " Registered Modules: " & SMGetRegisteredModules & " $register variable: " & $register
returns:
ERROR ? Registered Modules: ? $register variable: ?
Why would the same script work as a server scheduled script but not through custom web publishing? The script runs as full access so the only issue there should be with permissions is having access to the script itself, and we know the script is running due to the error writing.
sendBulkEmailScript.tiff
I'm not sure this is the main issue, but the first thing that strikes me from the screen shot is that your test for the function "SendEmailWithAuthentication" being registered, but the function that you then register and use is called "SendEmailWithHtmlAndReturnPath".
For this kind of use, it might be easier to get a ScriptMaster Advanced license and compile a custom plugin - I always find that it's nice to have one less thing to think about in my scripts.
(OFF-TOPIC: I was really glad to see that Crumpler Canada is running FileMaker when I was in the Vancouver store a few months ago - I'm a big fan of Crumpler! The layouts looked nice, as they should for a brand like yours.)
Good catch, but unfortunately, it's not the problem. SMGetRegisteredModules is only returning "?" anyway, which tells me that the server doesn't see the plug-in. Yet it works when you run it as a schedule... this is driving me crazy!!
I just knew it would be something stupid!;-)
Thanks.
Still can't get it going.
To try to narrow it down, at the top of my script I set the variable $version to SMVersion, and later output that to a field. The result is always "?" (to that and every other call to a ScriptMaster function).
Also, nothing comes up if I output Get ( InstalledFMPlugins ).
I found the login file "360Plugins_WebPublishing.log" in Library/FileMaker Server/Logs/360Plugin Logs
It seems to show that the plugin is being loaded just fine:
(C++ Thu Jun 28 22:30:18 2012) INIT - Creating new log file
(C++ Thu Jun 28 22:30:18 2012) *** INIT for 360Works ScriptMaster_WebPublishing at Thu Jun 28 22:30:18 2012, headless mode 1, appTypeShort 8
(C++ Thu Jun 28 22:30:18 2012) No existing JVM found; creating one.
(C++ Thu Jun 28 22:30:18 2012) Running in headless mode; starting JVM on main thread
(C++ Thu Jun 28 22:30:18 2012) Enabling headless mode
(C++ Thu Jun 28 22:30:18 2012) Java home dir was dynamically read: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home
(C++ Thu Jun 28 22:30:18 2012) 0: -Djava.awt.headless=true
(C++ Thu Jun 28 22:30:18 2012) 1: -Djava.class.path=noclasspath
(C++ Thu Jun 28 22:30:18 2012) 2: -Xbootclasspath/a:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/../Resources/JavaPluginCocoa.bundle/Contents/Resources/Java/deploy.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/../Resources/JavaPluginCocoa.bundle/Contents/Resources/Java/plugin.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/deploy.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/plugin.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/jaws.jar
(C++ Thu Jun 28 22:30:18 2012) 3: -Djava.ext.dirs=/System/Library/Java/Extensions:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/ext:/Library/Java/Extensions
(C++ Thu Jun 28 22:30:18 2012) 4: -Dcom.apple.eawt.CocoaComponent.CompatibilityMode=false
(C++ Thu Jun 28 22:30:18 2012) JVM started successfully - jvm references is 220702376
(C++ Thu Jun 28 22:30:18 2012) Call finished
(C++ Thu Jun 28 22:30:18 2012) fmkitUrl: file:///Library/FileMaker%20Server/Web%20Publishing/publishing-engine/wpc/Plugins/360Works_ScriptMaster.fmplugin/Contents/Resources/Java/plugin.jar
Jun 28, 2012 10:30:18 PM com.prosc.fmkit.PluginBridge initLogging
CONFIG: Will write normal log file to /Library/FileMaker Server/Logs/360Plugin Logs/360Plugins_WebPublishing.log
Jun 28, 2012 10:30:18 PM com.prosc.fmkit.PluginBridge initMac
CONFIG: Loading dynamic library at /Library/FileMaker Server/Web Publishing/publishing-engine/wpc/Plugins/360Works_ScriptMaster.fmplugin/Contents/MacOS/JaCK3
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.PluginBridge initMac
CONFIG: Loading plugin jar at /Library/FileMaker Server/Web Publishing/publishing-engine/wpc/Plugins/360Works_ScriptMaster.fmplugin/Contents/Resources/Java/plugin.jar
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.PluginBridge getPluginClassNameForPluginJar
CONFIG: Loading Plugin class named com.prosc.beanshell.BeanShellPlugin
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.PluginBridge <init>
INFO: 360Works custom SecurityManager has been installed
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.PluginBridge loadVersion8Lib
CONFIG: Loading the version 8 library from /Library/FileMaker Server/Web Publishing/publishing-engine/wpc/Plugins/360Works_ScriptMaster.fmplugin/Contents/MacOS/version8lib.jnilib
CONFIG: Version 8 lib was loaded successfully
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.PluginBridge fmxInit
INFO: Creating shared PluginBridge instance / plugin bridge version 1.64
bundlePath: /Library/FileMaker Server/Web Publishing/publishing-engine/wpc/Plugins/360Works_ScriptMaster.fmplugin/Contents/Resources
jvm version: 20.6-b01-415 from /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home - JAVA_JVM_VERSION is /System/Library/Frameworks/JavaVM.framework/Versions/1.6/
Operating system info: Mac OS X 10.7.3 running on i386 architecture
Temp directory: /var/folders/0d/0jlddp6j5375ck4qm9561pjm0000gp/T/
CONFIG: Initialize 360Works ScriptMaster
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.Plugin init
CONFIG: Created new plugin instance: com.prosc.beanshell.BeanShellPlugin named 360Works ScriptMaster; version: 4.132
Jun 28, 2012 10:30:19 PM com.prosc.license.client.Registration checkLicense
INFO: Registered successfully with demo license; will run for two hours after launch.
INFO: Expiration date Fri Jun 29 00:30:19 EDT 2012
Jun 28, 2012 10:30:19 PM com.prosc.beanshell.BeanShellPlugin init
INFO: Registered with hard-coded license key
Jun 28, 2012 10:30:19 PM com.prosc.beanshell.BeanShellPlugin customizeFunction
INFO: Function PluginFunction{name='EvaluateGroovy', functionID=28121, minArgs=null, maxArgs=1} runs in swing
Jun 28, 2012 10:30:19 PM com.prosc.fmkit.PluginBridge registerFunction
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='EvaluateGroovy', functionID=28121, minArgs=null, maxArgs=1}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMSetVariable', functionID=-3516, minArgs=null, maxArgs=2}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMGetVariable', functionID=-28360, minArgs=null, maxArgs=1}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMVersion', functionID=-12574, minArgs=null, maxArgs=0}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMLastError', functionID=26664, minArgs=null, maxArgs=0}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMLastStackTrace', functionID=-4147, minArgs=null, maxArgs=0}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMLoadJar', functionID=-32667, minArgs=null, maxArgs=1}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMReset', functionID=29931, minArgs=null, maxArgs=0}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='RegisterGroovy', functionID=6991, minArgs=2, maxArgs=-1}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMGetRegisteredModules', functionID=-16535, minArgs=null, maxArgs=0}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMGetLoadedJars', functionID=-15591, minArgs=null, maxArgs=0}
INFO: PluginBridge{instanceID=47718560} registering PluginFunction{name='SMCreatePlugin', functionID=-2359, minArgs=null, maxArgs=7}
CONFIG: Return VERSION_CURRENT: 51
(C++ Thu Jun 28 22:30:19 2012) *** INIT finished with result 51
What could I be missing here?
Can you tell me which version of FileMaker Server you are using so we can try to reproduce this locally?
Hi Brent, I'm using FMS 12.0.1.178
