Toggle between elapsed days and elapsed weeks and days
I have two fields - "toggle", which is a global, and "duration". Toggle has a value of either 1 or 0, entered by a script. Duration is a calculation field using the Case function to determine it's contents (result is text):
Case(
toggle = 0 ; enddate - startdate & " days" ;
toggle = 1 ; [insert week and day calculation here]
thing is, if the duration result in days is less than 7, then weeks aren't displayed (basically 0 or 1 would return the same result).
How do I turn days into week and days?
weeks = Div ( enddate - startdate ; 7 )
days = Mod ( enddate - startdate ; 7 )
Know thy Mod() function, when thou cometh to date calculations.
LOL, that's true (and strangely familiar...). But this is not really a date calculation as such - just your standard algorithm for dividing things into groups, like:
packs = Div ( beers ; 6 )
cans = Mod ( beers ; 6 )
Indeed, as dates are numbers, they fit here as well and your first calculation...
… displayed that correlation quite nicely … just as this is a number and a date calc; it doesn't matter whether using one date (producing total number of days) or subtracting one date from another:  Date - Mod ( Date - 1 ; 7 )
STOP!  YOU'RE BOTH RIGHT!  It's a floor wax AND a dessert topping!  (Saturday Night Live about 20 years ago)
Thanks comment and LaRetta.
Here is the calculation I came up with which works quite well:
If(not IsEmpty(start_date);If(not IsEmpty(end_date) ;
Case (toggle = 0 ; end_date - start_date + 1 & " days" ;
end_date - start_date  ≤ 6 ;  end_date - start_date + 1 & " days" ;
toggle = 1 ; Div(end_date - start_date + 1; 7) & "w " & Mod(end_date - start_date + 1; 7) & "d"))
I would like when toggle = 1 to also display months and years, IF the specified range qualifies for that extra info. Is this possible without completely changing the formula?
Say end_date - start_date + 1 = 800. How many years and months is that?
about 2 years, 2 months or so?
Yes, "about" being the operative word here. So do you want an "about" result or an accurate one? Because I don't know how to calculate an accurate answer in a meaningful way. Perhaps I should have picked a better number of days to demonstrate, say 393 (= 365 + 28). This could be one year and 28 days, or one year and one month - if that month is deemed to be a February. And if that year and the one that follows is not a leap year. In short, it could be anything you want it to be, and no one could say if it's wrong or right.
See also:
http://fmforums.com/forum/topic/35129-the-old-question-how-old-are-you/#166888
See also:
I see. I didn't realize the full extent of this, as you've explained. I suppose a rough estimate would suffice, but in the end I actually doubt it would be needed. Perhaps just months, weeks and days.
I get into a habit sometimes of thinking "how else can I display this data?" or assume a different situation and solutions the user may be presented with.
