A huge script problem...
My problem is simple. I have a web published database which includes 4 databases. It is a college end-of-year class evaluation system. The user logs into the student database, chooses their course from a course database, then takes the evaluation in a evaluation database which includes questions from a question database. My problem is this script. I have been able to find xsl and xml solutions to get around my other filemaker scripts that I have used but not this one. I am using a global field for portals to pass on information to the evaluation database and globals do not work with multiple users on at the same time. So here is the script:
1) Set RegistrationIDGlobal in Evaluation Database to RegistrationID in the Course database.
2) Go to layout (questions portal)
3) Go to portal row (select, first)
4) Set field (gcounter, 0)
5) Loop
New Record
Set field (gcounter, gcounter + 1)
Go to portal row (gcounter)
Set field (QuestionID, zk.constantQuestions:QuestionID)
Set field (RegistrationID, RegistrationIDGlobal)
Exit loop if (gcounter >= cnumber of questions)
End loop
A quick review of what each step does:
Set registrationIDGlobal in Evaluation Database to RegistrationID in evalcourse. The registrationID is simply a way of administrators to keep track of who has taken an evaluation. It consists of the PIDM (a personal student ID) and the course ID (ex. math 303). I am setting the global in evaluation database for the future part of this script.
Go to layout (questions portal). I know this is easily done with -lay. I am using this primarily to get the info from the portal for future steps in this script. I have placed the portal in this layout.
Go to portal row (select, first). In the portal there are all the questions from the questions database. In this script step, I am instructing it to go to the first question.
Set field (gcounter, 0). gcounter is a global field and is used to set the questionID which is used in one of my relationships in Evaluation Database in order to get the question there. gcounter increases later on by way of the loop and therefore I am able to use this relationship.
Loop
new record. I start the loop by adding a new record to the evaluation database. Each record in here consists of a question and response and the registrationID.
set field(gcounter, gcounter + 1). Here I am increasing the global field to the next QuestionID.
Go to portal row (gcounter). I am getting the question in the portal based on whatever gcounter equals.
Set field (QuestionID, zkconstantQuestions:QuestionID). Based on the current row in the portal, I get the question ID.
Set field (RegistrationID, RegistrationIDGlobal). With the global that contains the RegistrationID from the Course database from before, I set the RegistrationID in Evaluation database to equal whatever is in the global.
Exit loop if (gcounter >= cnumber of questions). The loop is finished and I stop adding records if the global gcounter( which is increased by one every time) is equal to the number of questions in the questions database.
End loop.
My problem is the globals with multiple users on the internet. I have tried the process with two users at the same time and it added 2 times the amount of records in the evaluation database as I wanted. Also I have been told not to use scripts on the web but I do not see a way around it with this script.
Justin
  • 2 weeks later...
The answer is simple: Lasso or PHP. cool.gif
What about ASP? My college is using ASP as a standard so I have to use it to instead of PHP. I know its possible as I have seen a little bit of resources out there but no where near as much as PHP and the FX.php class. It will just take a little extra work is all...
Haha, more than just a "little" work. I'm currently writing another version of the PHP FX class for ASP 3.0 using JScript. As soon as its ready for some beta testing I'll make it available (free, of course). If you want to try it out, send me an email and I'll respond with the code that I have so far.
