FileMaker 2026 Released
I have problems with date finds... Help!
Here are my fields:
"Date" is defined as a date field in File A
"gDate" is a global (date) field in File B
And this is what I'm trying to do:
Enter Find Mode []
Set Field ["Date", "">="&File B::gDate"]
Perform Find [Extend Found Set]
But I noticed that it instead inserts weird numbers with "/". What is the proper way to insert a " >= " in a date field?
Chard
Hi Chard,
I have *not* tested this, but I think you need to use the TextToDate in your Set Field:
Try
Set Field ["Date", "">=" & TextToDate B::gDate"]
HTH
p.s.
Make sure your gDate is formatted as a Date Field.
Hi Lee!
Nope, I tried the TextToDate function and checked that all fields are date fields and the other is a global date field, but it just inserts a "?" in the date field in Find Mode. Any other ideas? I'm really stuck with this thing.
Just an update on my problem. I don't know why, but I tried this:
Insert Calculated Result ["Date", "">=" & DateToText(File B::gDate)"]
But it works for me!
Does this mean you can't use Set Field when using "&" in Find Mode?
This is where Insert Calculated Result comes in. Any time you're setting a field with an expression that doesn't exactly equal the field's format (mostly date and time fields) use Insert Calculated Result. This will not try to force the result into a date or time format, as Set Field will.
Insert Calculated Result [Date, ">=" & DateToText(gDate)]
or Insert Calculated Result [Date, ">" & DateToText(gDate - 1)]
You can't use "Set Field" with a Date, it has to be Insert Calculated result. I tested this one and it seems to do what you want.
Go to Layout [original layout]
Enter Find Mode []
Insert Calculated Result [select,
