Problem with decimal places after publishing onlin
I have no problem defining fields and telling numbers to have 2 decimal places while in Filemaker, but once the information is published online they seem to get a mind of their own. For instance, in Filemaker I can view
I just tested this with FMP7 IWP and it seems to work fine, but if you're using v6, that isn't very helpful. One way around this would be to display the data using calculation fields which round to the appropriate digit.
Howdy! I just copied 133.493828434 and pasted into a number field and then set the field format on the layout to 2 digits and I see 133.49 until I click in it and then I see the long value. On IWP, it shows up as 133.49 until clicked in, just as in FM. I did not use the
Beleive it or not this is a calculation that I use as a custom function in FMP7 that adds comma's and decimal.
This is what we use to display numbers on the WEB as we had the same problem
(number_to_comma_gn) is the number you want to display correctly
"$ " & If( GetAsNumber(Int(GetAsText(number_to_comma_gn)) &
Case(Int(GetAsText(number_to_comma_gn)) = GetAsText(number_to_comma_gn);".00"; Left(Mod(GetAsText(number_to_comma_gn); 1) &
"00"; 3)))>999; Left(Int(GetAsText(number_to_comma_gn)) &
"00"; 3)); (Position(Int(GetAsText(number_to_comma_gn)) & Case(Int(GetAsText(number_to_comma_gn)) = GetAsText(number_to_comma_gn);".00"; Left(Mod(GetAsText(number_to_comma_gn); 1) & "00"; 3)); "."; 1; 1)-4)) &
"," & Middle( Int(GetAsText(number_to_comma_gn)) &
"00"; 3)); "."; 1; 1)-3); 20); Int(GetAsText(number_to_comma_gn)) &
"00"; 3)))
Hope this helps
Stu
